2015 Ram 2500 aftermarket rims change alignment
Old 07-29-2015, 09:48 PM
Greasy24's Avatar
Greasy24
Greasy24 is offline
Default 2015 Ram 2500 aftermarket rims change alignment
I recently purchased new rims for my truck 20x10 5in backspacing -12 offset. After having them installed my steering wheel was off center and my alignment was crooked. So i put my stock rims back on and its back to normal has anyone else had any issues like this on there truck?
Old 07-29-2015, 10:24 PM
jkeaton is offline
Dodge Forum Administrator
Who installed them?
Old 07-29-2015, 10:41 PM
Greasy24's Avatar
Greasy24
Greasy24 is offline
My local Discount Tire. I told them and they suggested a feont end alignment. I just had them put the stock wheels back on today because a hub cap came loose and scratched the crap out of one of the rims. Im gonna have to tell them the stock tires fixed the alignment problem and see what they say.
Old 08-07-2015, 01:10 PM
Greasy24's Avatar
Greasy24
Greasy24 is offline
well seeing nobody else commented im guessing its something to do with the rims i choose! I don't see how putting a offset rim would change the geometry's of the front axle.
Old 08-07-2015, 01:29 PM
Greasy24's Avatar
Greasy24
Greasy24 is offline
Im gonna level my truck then get a front end alignment.
Old 08-07-2015, 06:35 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Level with springs, spacers will sit crooked with the front aligned.
To fix your current issue, set both camber bolts to 6 O'clock then you should be close. Eyeball the bolts till everything is centered. Even dealers are throwing away alignment specs and eyeballing it on 2013+ HD trucks.
Changing ANY spec on these new front ends effects not only alignment but also ride height, specifically the drag link and center link. Even something as simple as backspacing will effect it...
Old 08-07-2015, 07:31 PM
Greasy24's Avatar
Greasy24
Greasy24 is offline
Awesome thanks for the info, i was worried about using spacers. Im glad i finally heard some info about this, I was losing hope.
Old 08-08-2015, 11:47 AM
p38251's Avatar
p38251
p38251 is offline
Rough country makes new coils. That will give you 2". Which is level.
Old 08-08-2015, 12:01 PM
Greasy24's Avatar
Greasy24
Greasy24 is offline
Thanks ill look into them.
Quick Reply: 2015 Ram 2500 aftermarket rims change alignment
