question about welding on my frame
Old 09-13-2007, 11:26 PM
57ringo's Avatar
57ringo
57ringo is offline
Default question about welding on my frame
I'm putting a gooseneck hitch on my 05 Dodge CTD. I'm welding some extra brackets on the frame. do I need to take the battery cables or alternator cables off? I don't want to fry anything electrical.
Old 09-13-2007, 11:58 PM
Parts/Service's Avatar
Parts/Service
Parts/Service is offline
Default RE: question about welding on my frame
Never weld on the frame.....
Old 09-14-2007, 12:31 AM
57ringo's Avatar
57ringo
57ringo is offline
This is a rebuilder. I've welded on frames for years....just don't want to fry something electrical.
Old 09-14-2007, 12:33 AM
spaz_22's Avatar
spaz_22
spaz_22 is offline
i would unplug the battery just to be safe, becuase you never know...
Old 09-14-2007, 12:34 AM
jakebrake's Avatar
jakebrake
jakebrake is offline
Your supposed to disconnect the batts if ya have to do any welding. That being said, as long as you have a good ground on the piece your working on, you shouldn't have a problem.
Old 09-14-2007, 07:35 AM
triton's Avatar
triton
triton is offline
you may have welded on frames for years but, that was probably when they made vehicles. The frames on these trucks are paper thin and any welding will remove it's structural integrity. Dodge actually has a TBS out that says NOT to weld to the frames. It also said there are only a couple places that can even be drilled into. I'd say if you're going to do it... it's at your own risk !
Old 09-14-2007, 07:50 AM
57ringo's Avatar
57ringo
57ringo is offline
Will the radio work after taking the cabels off or do you need to put a code in it again?
Old 09-15-2007, 05:28 AM
HankL's Avatar
HankL
HankL is offline
The newer Ram frames are made of
HSLA (high strength low alloy) steel
and need special welding techniques and choices of filler rods/wire.
Lord Corp has some amazing glues that most body shops now keep in stock for repairing vehicles. These glues actually make a stronger/tougher bond than most stick welding. You might explore using some Lord glue for your brackets along with bolts.
Old 09-17-2007, 10:23 PM
57ringo's Avatar
57ringo
57ringo is offline
got the brackets welded on and everything still works.
Old 07-14-2015, 09:10 AM
57ringo's Avatar
57ringo
57ringo is offline
Just thought I'd update for you guys that are afraid to weld on frames, it's been 8 years and no problems were I welded and I've pulled some heavy loads.
Quick Reply: question about welding on my frame
