1999 Ram Van 5.9 won't start and fuel gage not working
I thought for a while it was the relays, but I have swapped all the relays around in the fuse box so they seem fine. Every once in a while I can get it to work, but mostly it turns over and doesn't fire as if there's no fuel. Sprayed some starter fluid in the air intake and got it to chug a little so spark seems ok.
The wierd thing being, if the fuel gage shows no fuel, then I know it's not going to start. It has a half a tank of gas in it.
Is this a computer problem? Should I see if I can borrow a diagnostic unit and get some codes?
Herb
Herb
Might be a bad ground for the fuel tank gauge and pump motor. Check the ground wire near the right rear door near the back side of the door hinge side jam. Clean and reattach that ground strap and see if that solves your problem. Otherwise you might need to drop the tank and check the connections on the pump module.
Progress report: disconected the wire coupler to the tank. Checked for voltage. Had a little less than 12 coming from one wire while key was in the on position. Then re connected and showed fuel and started. It did however quit running once. It seems to run now but havnt driven it yet.
I'm not sure where your talking about w the ground strap location. I have an extended van with a slider side door. I couldn't see any ground strap anywhere near the tank from the underside.
Guess I may need to drop the tank? Any more help on where that ground strap might be located?
I've pulled the trim at the step in area at the sliding door (passenger side) and don't see any ground. I assume you mean passenger side when you say right side. I am going to pull up the rubber floor and check the driver side because that is the side the fuel tank is on anyway. Not sure why the ground wouldn't be on that side.
Trending Topics
My tank is plastic, so I guess if that's the ground you're talking about, there isn't one.
So I replaced the fuel pump unit for $220 and at least I can rule that part out, cuz it's still broken...
What I do know is that when the key is on, I am getting 11.37 volts or so from the light blue/black wire, and that both black grounds are grounded from the harness before the tank. Can't test the other hot without someone turning the key I guess, but that one is not registering voltage. Again - gas gage not registering properly.
I'm not sure what that tells me. I am trying to look at the wiring diagram from the full manual to find some info, but I'm wondering now if it is a bad computer. I do have a lot of lights that come on and off randomly - the brake and ABS, the check engine occassionally. Never had it checked for codes, probably should have I know.
I'm about to tow it to a mechanic soon. Be nice if I could figure it out tho.
Needs a PCM,tap on the pcm with a small hammer,dont beat the crap out of it.DDodge is having a major PCM issue,the guages go out,wont start,you can tap on the PCM or disconnect the 3 connectors and plug them back in and wiggle them up and down,the PCM have a internal crack or something in the circuit board.This made my van start,and dodge won't replace it,it is out of warranty,but a 2001 with 40,000 on it,this pcm should last a fricin life time,but no,they stuck it in my too too and wont replace it.Going to cost me$700.00 to replace,if you can find one,major backlog,backorder big time,GOOD LUCK,hope this gets it started for you,may die out again,but will start.
