Newer 318 or bigger motor
Old 07-14-2015, 07:59 PM
jb0015415's Avatar
jb0015415
jb0015415 is offline
Default Newer 318 or bigger motor
Just wondering what my options for an engine swap would be. I have a 1981 b250 camper van with 318 2 barrel. The engine is very tired and i would like more power. What could fit with minor adjustments? Or should i just source another 318 of the same year and put some mods on it.
Old 07-14-2015, 08:00 PM
jkeaton is offline
Dodge Forum Administrator
360 would probably drop right in.
Old 07-15-2015, 07:45 AM
rsdata's Avatar
rsdata
rsdata is offline
I'm a big believer in trying chemicals to juice up your engine...
cheap enough to try... I like these two products
http://www.amazon.com/Restore-00016-8-Cylinder-Restorer-Lubricant/dp/B00HJVEX74/ref=sr_1_2?s=automotive&ie=UTF8&qid=1436960642&sr=1-2&keywords=restore+engine+restorer&pebp=1436960643966&perid=1G81Z7FCEHMKKW524Y28 http://www.amazon.com/Restore-00016-8-Cylinder-Restorer-Lubricant/dp/B00HJVEX74/ref=sr_1_2?s=automotive&ie=UTF8&qid=1436960642&sr=1-2&keywords=restore+engine+restorer&pebp=1436960643966&perid=1G81Z7FCEHMKKW524Y28
Motorkote
http://www.walmart.com/ip/MotorKote-...32-oz/19887630
I saw an immediate improvement in pickup after using one bottle of Restore and continued imporvement after using 2 and 3...
Motorkote goes in all oiled areas, engine, transmission, diff, power steering...
use according to directions on bottle
Old 08-06-2015, 06:10 AM
blackvan's Avatar
blackvan
blackvan is offline
In that vehicle, a 360 should bolt right in and give the the best bang for the buck.
Old 08-06-2015, 12:17 PM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Dodge Forum Moderator
Bolt in yes, but remember the 318 is an internally balanced motor while the 360 is an externally balanced motor and requires the torque converter with the weight on it. Without the weight the engine will shake itself apart.
Old 08-08-2015, 11:04 PM
blackvan's Avatar
blackvan
blackvan is offline
Apologies for my omission, I forgot. Alloro is correct. Swapping to a 360 will also require swapping to a torque converter/flexplate designed for the 360 engine but other than this it should present no problems.
Old 09-07-2015, 10:31 AM
2 Dodge Vans's Avatar
2 Dodge Vans
2 Dodge Vans is offline
I'd go with the larger 360 ; even with low miles my carbed 318 is just feels to taxed in my 250 conversion van. Seems a good used 360 would be about the same price as a 318 anyway.
Old 09-12-2015, 01:24 AM
Tommy555's Avatar
Tommy555
Tommy555 is offline
I'd rebuild the 318. No reason to drop in a slightly bigger motor. Save parts and cash... you're not going to notice anything with the 360.
Old 09-15-2015, 09:17 AM
iodj44's Avatar
iodj44
iodj44 is offline
The difference between a 318/360 will be felt when you load the van and drive up long or steep grades.
Like others have mentioned you need a 360 TQ converter other than that you should have a straight forward job.
I always like to remind folks removing/installing van engines is a serious job especially your first time.
Old 09-16-2015, 08:47 PM
SteveR's Avatar
SteveR
SteveR is offline
Yes, the Hayne's manual for the Dodge vans has a good write-up on pulling the 360. I believe they say to remove the exhaust manifolds first. Having to deal with the AC system would be a pain too, that's something you'd probably want to have done at your place if possible.
Is it possible to exchange a 1991 TBI 318 with a same year 360?
Steve
Quick Reply: Newer 318 or bigger motor
