Replacing Governor Pressure Solenoid & Sensor
Old 08-31-2015, 10:15 PM
BudhaRizzo's Avatar
BudhaRizzo
BudhaRizzo is offline
Default Replacing Governor Pressure Solenoid & Sensor
Found this great video on how to replace the Governor Pressure Solenoid and Sensor on your transmission.
Old 09-04-2015, 05:40 AM
blackvan's Avatar
blackvan
blackvan is offline
Agreed, which is why I posted it two years ago. Still, its important enough to have its own thread so thanks for bringing it to everyone elses attention again.
https://dodgeforum.com/forum/dodge-r...ml#post3119087
Old 09-06-2015, 04:23 PM
jrp79's Avatar
jrp79
jrp79 is offline
I removed the solenoid and sensor.there was alot of sludge on the pan magnet but no metal shavings in the fluid but fluid was brownish.
the passage on the top screen on the solenoid was almost blocked.
how do I test the sensor and solenoid
Old 09-09-2015, 03:58 PM
BudhaRizzo's Avatar
BudhaRizzo
I could be wrong, but I don't think you can test them individually. The best thing I can come up with is to put it all back together, top it off, then run the van while running an OBD scanner to see if it pops codes. Sorry if this doesn't help.
Old 09-10-2015, 05:28 AM
blackvan's Avatar
blackvan
blackvan is offline
Quick Reply: Replacing Governor Pressure Solenoid & Sensor
