Stuttering help!!!!!
Old 09-22-2015, 02:55 PM
89 van man II's Avatar
89 van man II
89 van man II is offline
Default Stuttering help!!!!!
I have a 89 b250, I did a smog delete, installed some Moog 7272 coil springs but other then that its stock 318 tbi.
I need help because my van started having this real bad hesitation problem when I hit the gas, when the van is cold its like a bucking bronco it does get better after driving a while but still does it.
I have replaced the following already: tps & map sensors, cap & rotor, fuel pump-strainer-fuel lines & fuel filter.
I am at a loss.......maybe a vacume leak?????? but this must have happened to someone else????
Old 09-22-2015, 05:20 PM
SteveR's Avatar
SteveR
SteveR is offline
Air filter, sparkplugs and wires should be done too. This is a common problem when a tune-up is due.
Steve
Old 09-22-2015, 11:30 PM
landyacht318's Avatar
landyacht318
landyacht318 is offline
Detail smog delete. If you removed 02 sensor, there is your answer.
Otherwise, whenever I have had hesitation on my '89, it has been spark plug wires.
Also it is possible that you have a bad ECM connector, and this might not set a computer code or flash the check engine light.
Turn key to on, not start, wiggle connectors at engine computer, and see if you hear relays click on and off or the idle speed motor moving when you wiggle the connector.
Old 09-23-2015, 02:47 AM
Rambelle's Avatar
Rambelle
Rambelle is offline
I know about 3% of bugger all, so please excuse the ignorance but my intentions are to help. I have indeed suffered similar sudden behaviour like you describe and the cause was a damaged fuel cap. The air hole was clogged and caused a vacuum in the fuel line/emission dohickies. A quick poke around and clean up and no more stuttering. Hope this is relevant and helps.
Old 09-23-2015, 02:54 AM
Rambelle's Avatar
Rambelle
Rambelle is offline
Default Stuttering help!!?!
Old 09-23-2015, 10:09 PM
j404ski's Avatar
j404ski
j404ski is offline
My jeep did the same thing. Was the timing chain. Does yours backfire?
Old 09-30-2015, 10:15 PM
Tommy555's Avatar
Tommy555
Tommy555 is offline
Plugs, wires and coil need to be done. You only did a partial tuneup.
Old 10-03-2015, 10:49 PM
funair02's Avatar
funair02
funair02 is offline
check
Quick Reply: Stuttering help!!!!!
