New Features: Dodge Knowledge Base - check it out & suggest new topics here.
DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stealth
Thread Tools Search this Thread
Old 05-04-2006, 03:38 PM
thestealth's Avatar
thestealth thestealth is offline
My Garage
Default Buying a Stealth
Buying a used car is always a tricky proposition, Stealths are no different.
First off, I'll list some of the common issues prevelant to all the models.
1. Capacitors. Mitsubishi used subpar capacitors in the control boards. These capacitors will start leaking, damaging the circuit board they are on causing all sorts of malfunctions or board failure. They can be replaced for a minimal cost in comparison to the price of a new unit.
These capacitors are in the ECU (engine controller), TCU (Auto tranny controller), ECS (Electronic Controlled Suspension), and the Digital Climate Control. When I had them replaced on my car, I used ECM to go. They had a fair price and a car on site to test their work.
Edit: Upon further research, this is only an issue with the 1st gen cars, 91-93.
2. Cracked dash vents. Purely a cosmetic problem, but very common. To replace them requires the removal of the dash. I personally am just living with it.
3. Bubbling of the interior door panels. The outer "skin" of the door panel becomes seperated, making bubbles appear in the door panels. Another cosmetic issue, no known cure other than to replace the entire door panel.
4. Worn seat bolster on drivers seat.
5. Lifter tick. Very common among the DOHC engines, I'm not sure if the SOHC has this problem or not. More of an annoyance than anything, as it is not detrimental to the engine. Keeping the oil changed with Synthetic oil will lesson the ticking, but even then it will happen. I change the oil on my Stealths around 3000 miles and both of them have very minimal lifter tick.
Those are the main problem areas of all the models, base, ES, RT, RT/TT. When looking at used cars (any used car), always check the fluid levels and conditions and ask for maintenance records. This is a good indicator of how well the previous owner cared for the vehicle. Kick all the tires, don't be afraid to crawl all over and under the vehicle looking for rust, overspray from a repaint, missing nuts/bolts, hidden damage, etc. Run a carfax report. Not all accidents will show on a carfax, but it will at the minimum give you an idea of how many owners the car had and whether of not the mileage on the odometer is correct. Don't be afraid to ask the owner questions; Why are you selling it? How long have you had it? Any known problems? Etc. Test drive it. Don't turn on the radio while test driving, listen for any unusual clunks or sounds. Drive on varied pavements to listen for any suspension issues. Punch it a time or too (I am not advocating ragging out someones car) to make sure it runs like it should.
The truth is, these cars are starting to get old(er). There will be things that will break or just plain wear out. Struts, seals, hoses, belts, misc. electronic items, chassis and suspension bushings. This is common on all vehicle when they age.
Maintenance
The DOHC and TT engines require a little more thorough maintenance than their SOCH brethren. Every 60K miles the timing belt, water pump, pullies and tensioners, spark plugs should be changed. At 180K miles, the oil pump should be changed, it is not a bad idea to have the mechanic check the bearings while he is there.
That is all I can think of at the moment. Please feel free to add anything I might have missed, or correct anything in error.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-30-2006, 09:37 PM
rhinotsh rhinotsh is offline
My Garage
Default RE: Buying a Stealth
I'D LIKE TO ADD ,
PAY SPECIAL ATTENTION TO THE LOWER BALL JOINTS , RIGHT UNDER WHERE THE CV JOINT GOES THRU THE BRAKE ROTOR . YOU WANT TO MAKE SURE THE BALL JOINT IS IN GOOD CONDITION BECAUSE IF YOU NEED TO REPLACE THEM YOU HAVE TO BUY THE WHOLE "A " ARM AND I'M TOLD BY THE LOCAL STEALERSHIP THAT THEY START AT $575.00 !
Old 07-18-2006, 12:31 AM
jakster jakster is offline
My Garage
The lower ball joints can be had from several sources. First off you don't need to replace the whole arm just the balls $75.00-$125 each depending on the vendor. Tie rod ends about $45.00 each NAPA Auto.Look to www.3sxperformance.com for ball joints and you will have a good trip.
My old Stealth has 235.000 miles on the engine and just made a trip from Florida to Colorado / New Mexico and all over the place 3000 miles no problems not even with the rebuilt computer which I did myself for $20.00. This car is really high tech but if maintained will run for a very long time its all a learning curve don't trust the garage teach yourself what makes this beast tick they really have no idea at 99% of the garages.
The Jakster
__________________
<///////// If You Want It To Last Drive It Fast \\\\\\\\\\>
Red ES 17" Momo Corse Rims /Toyo Tires /custom exhaust/Custom Seats. Even the dings are custom.
Old 03-06-2007, 04:54 AM
rrjii2000 rrjii2000 is offline
My Garage
Lets not forget about the Defrost Vents deforming over time.On around the 10th aniversary of my Stealth the engine mounts were shot, and needed replaced. Also the exaust downpipe will rust out and break with no warning, turning your stealth into one mean noise machine. Mine sounded like a lawnmower, and I was several miles from home at the time
Rob
__________________
2007 Acura MDX Sport/Ent
2005 Dodge Viper SRT10
2004 Jeep Grand Cherokee Ltd
2000 Pontiac Trans Am
1992 Dodge Stealth RT
1991 Dodge Stealh RT Turbo
Old 01-16-2008, 10:36 PM
car5car car5car is offline
My Garage
Price of motor mounts is about 120 doll each. I made 2 mounts, it cost me about 5 cents each! If you buy Stealth, check mounts. Not even necessary to check, they are bad! Timing belt, water pump, seals-$500
__________________
You will get a lot of useful info from my site http://www.supermechanic.info/
Old 08-12-2008, 10:19 AM
Sturly Sturly is offline
Junior Member
My Garage
Vehicle: My name is Steve, I love cars, movies, music, and hanging out.
I always thought about picking up one of these cars, but they have such a bad rep reliability wise I was always too afraid. picking up a tt car would be sick as hell though!
Old 10-29-2008, 01:39 PM
materialman materialman is offline
My Garage
Do your homework and especially on the Twin Turbo's, make sure you have someone that knows what they are looking at check the car out carefully. These and not cheap cars to have worked on. If you can find a nice one, you will enjoy it!
92 Twin Turbo, original owner, Firestorm Red 15,000 miles, absolutely mint
07 Hummer H3
04 Lexus RX330
02 Dodge Dakota
92 Dodge Shadow
86 Ford Mustang GT Convertable
Tags
1991, 93, ball, capacitors, computer, dodge, ecs, joint, joints, napa, parts, replace, stealth, tcu, tt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
