Belt help
Pearl01stratcpe was referring to a remanufactured power steering pump, if that was the problem. As far as the "rack to cooling" line, I don't know if that's the pressure or return. Most likely the pressure line, ask your mechanic to clarify for you. You can go to rockauto.com. The pressure and return hoses are @$20 each. Probably your local parts stores carry them as well.
I wish I could have done this with my messed up AC, I had to replace the compressor this week, really don't need the AC right now except for defrost, I would have deleted it for the time being but the 3.0 only had the 6 rib belt with AC so to find the correct belt size would have been trial and error
