PCM/ASD fuse keeps blowing - 1998 stratus 2.4
Glad that you got your problems sorted out, and glad to have helped with the "thinking through" process.
Side question: in the pic you posted, the support bracket for the TCM has the front flange bent back at an angle; has it always been that way?
Question…
Can you help me … where is located that “noise suppressor” component.?? Inside of the car in the radio? I have the same problem… I took all sensor out 02, EGr, manifuel sensor, and still keep blowing fuse. Hope you can help me
It ended up being a short in the "noise suppressor" which I completely missed until a dodge mechanic sent me a real wire schematic.
But... Even though the car runs and drives fine, the radio and power locks no longer work. Also I can no longer plug my code reader in, it just doesn't detect the car or something.
In case it's relevant, I had a check engine light about a month ago (before all this happened) for P0134 and the "most common fix" was a new PCM(ECU).[/QUOT
