Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
can you put a turbo on a 4 cylinder?
Old 09-06-2005, 04:40 AM
TheGreek's Avatar
TheGreek
TheGreek is offline
Default can you put a turbo on a 4 cylinder?
can you put a turbo on a 4 cylinder.
YES I AM A SEVER NEWB (SEVER NEWB ALERT)
but i want to know if it will damage anything. cause well a 4 cylinder doesent have good take off time and i wonder if it will help it out
Old 09-06-2005, 03:25 PM
BadStratRT's Avatar
BadStratRT
BadStratRT is offline
The Forum Tyrant
Dodge Forum Administrator
Default RE: can you put a turbo on a 4 cylinder?
a 4 cylinder what? because technically, you can put a turbo on anything
Old 09-06-2005, 06:55 PM
MChat's Avatar
MChat
MChat is offline
Yes. Alot of modern 4 cyl engines (Crank, Block & Head) can take quite a bit of abuse. How much boost a particular engine can run depends on what it is and what's been done to it. Typically to run any decent amount of boost, the engine needs to be rebuilt with forged components (rods & pistons). Other engines come from the factory pretty beefy, like the SRT-4 2.4L I4; I'm running 20psi of boost daily on my stock engine.
Old 09-06-2005, 07:34 PM
TheGreek's Avatar
TheGreek
TheGreek is offline
not for racing purposes. just so I dont get run over taking off out of neighboor hood.
5 lane road.
its a dodge dakota 96 thats why I am asking.
The engine has been rebuilt but not with any peformence parts.
it was a sitting junk when I got it. now its been rebuilt and it has a few sqeaks here and there.
Old 09-07-2005, 02:03 AM
TheGreek's Avatar
TheGreek
TheGreek is offline
what about that turbonator thing.
Its cheap and Im not looking for 20 psi or anything like that.
just something to get me off from a stop onto a road in traffic.
Old 09-09-2005, 03:59 AM
injmopar's Avatar
injmopar
injmopar is offline
Sounds like a fun project. You can probily get all the parts from a car with the same engine at the wrecker. Don't forget to take all the heat shields.I know someone who did a swap and a mounth later the paint started to bubble.
Old 09-09-2005, 01:28 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
turbonators dont do anything..dont waste your money!
Old 10-03-2005, 04:56 PM
Joelzy's Avatar
Joelzy
Joelzy is offline
A turbo wont help you that terribly much on take off.... turbo lag will knock out the jump youre looking for.
I have a 2.5 dakota as well, Im looking into turbo-charging my truck with an older turbo off a used chrysler or dodge car. Ive been told that the leBaron turbos need the minimal fabrication to work and that the daytonas may work too. It ought to be a pretty interesting project.
If youre looking to just give it a little help you should make yourself a custom intake or you can buy one for a lot more. maybe exhaust as well.
I just sea foamed my motor and the difference is unbelievable. it runs so smooth and so much quicker so you could try that too..
I resurrected my truck too, the guy before me didnt take any care of it. but im slowly fixing her up
Old 10-06-2005, 04:35 AM
71RoadRunner's Avatar
71RoadRunner
71RoadRunner is offline
It all depends on the size of the turbocharger. The larger they are the more power they produce, but the slower they are to build power. The smaller they are the lower the power they produce, but the quicker they start producing it. That is why the SRT-4's have such a problem trying to launch during a race or even just spirited driving, their small turbocharger brings on the power so quick that they usually just melt the tires. The only problem with the small turbocharger is it's limited power building potential, the SRT-4's stock turbo is only good for 300+ horsepower. To get more out of it you need to put on a bigger turbo which will make more power yet be less responsive.
Old 10-06-2005, 07:28 AM
vestpuzzle1's Avatar
vestpuzzle1
vestpuzzle1 is offline
blah, blah, blah.
Quick Reply: can you put a turbo on a 4 cylinder?
