2000 ram 2500 starts but won't move in any gear
As the title states I've got a 2000 ram 2500 5.9 gas. Rebuilt the trans last year and drove without issue other then the truck itself is a dog and I'll assume that's due to the factory reprogram on the pcm. It starts and runs drops into all the gears no issues I've checked to make sure the truck is pumping fluid which it does fluid is full but I get no codes for any sensors. Before it was rebuilt when I got it the lever for the band was in the bottom of the pan and wouldn't engage to shift out of first. The only thing that's not hooked up is the airbags while I wait for new dash top to put it back on the road and it has sat for almost a year not moving but started at least once a month.
Do a pressure test, it will tell you if the accumulator/servos are getting adequate pressure. Was the check valve removed from the trans line? They have been known to stick.
http://www.atraonline.com/manuals/se...0/2000_154.pdf
