What type gear oil for tranny?
Old 01-09-2017, 08:23 AM
armynurse's Avatar
armynurse
armynurse is offline
Default What type gear oil for tranny?
We've got a 2006 2500 with the Cummins diesel and a standard tranny (GK56 by Mercedes). What kind of tranny fluid does it use? One place tells me to use ATF-4; another place tells me to use straight gear oil.
We're getting ready to put a clutch in it, and I don't want to ruin the tranny afterwards!
Thanks.
Old 01-09-2017, 07:09 PM
p38251's Avatar
p38251
p38251 is offline
Check your owners manual. I do believe it is ATF + 4
Old 01-10-2017, 08:11 AM
jkeaton is offline
Should be stated in your owners manual. If you don't have one, you can go here and download one for free.
https://www.mopar.com/ramtrucks/en-u...er-manual.html
Old 01-19-2017, 07:44 PM
superbrowndude's Avatar
superbrowndude
superbrowndude is offline
You may use ATF+4 or Valvoline Max life ATF fluid, the Valvoline fluid covers the ATF +4 specs and may be cheaper. DO NOT USE STRAIGHT GEAR OIL!
Old 01-21-2017, 02:58 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
Apparently, that's a manual tranny. ATF may not be a good idea.
Old 01-21-2017, 03:47 PM
superbrowndude
Sorry, if it's manual gear Oil would be required. Just need to find out the correct weight.
Old 01-21-2017, 09:10 PM
p38251's Avatar
p38251
p38251 is offline
Better check. Many manual transmission use ATF
Old 01-21-2017, 09:15 PM
p38251's Avatar
p38251
p38251 is offline
Okay Benz recommends 75/90 gear oil. Ram says ATF +4. IMO I would use what Benz says. They built it.
