Rough Idle...
Old 01-17-2017, 09:04 PM
adamratcliff's Avatar
adamratcliff
adamratcliff is offline
Default Rough Idle...
I have an '01 1500 5.2. It runs great, with one exception. If it sits for a day or so, (over 24 hours) I have noticed it will run at start up for a few minutes with a rough idle, then the idle levels out and it idles fine. Only once, has it back backfired at start up, at that time, it g as d sat for about a week.The computer is not setting any codes, so the computer is not helping me with the issue. I have not done a tune up, but plan to soon, changing cap/rotor, plugs, wires, air and fuel filter. I was wondering if it could be the IAC Valve or the AAT Sensor..? Anyone have any suggestions..?
Old 01-17-2017, 09:18 PM
dbbd1's Avatar
dbbd1
dbbd1 is offline
Yup, start with the IAC. Clean it and the mating part in the TB.
Old 01-18-2017, 07:29 AM
Fuel filter isn't exactly user serviceable either..... it's part of the fuel pump module, and generally gets changed when you need a new pump.
Old 01-20-2017, 09:05 AM
adamratcliff
I do have issues with the fuel gauge fluctuating, once I have less than 1/2 a tank of fuel. I have a new fuel pump, but haven't had time to install it.
