01 ram 4x4 suspension.
Old Nov 16, 2016 | 09:09 PM
David Clauder's Avatar
David Clauder
Default 01 ram 4x4 suspension.
Doesn't a 4x4 have a 3" block for stock suspension in the rear and the larger coil springs in front? If so if I switch out the coil springs for a 3" lifted coil spring with a 2" spacer...what would that do ? I installed the lifted coil spring and it brought the front end down to stock height and when I added the spacer it leveled it out. Am I missing something? My front end is a lil softer than it was before with the spacer and 2500 coil springs but not as soft as I thought it would be plus I have rough country n2.0 3" lifted shocks as well. Just trying to figure out why I still have an iffy front end. All ball joints were replaced and all suspension joints r solid and good. Just want my truck to ride good again and not feel ****ty going over bumps.
Old Nov 17, 2016 | 09:01 AM
Yep, 3" blocks in the rear are stock.
If you put a 3" spring, plus a 2" block up front, you are going to cause more problems than you solve. 3" lift is max without addressing the rest of the front suspension.
Old Nov 17, 2016 | 09:31 AM
David Clauder
There's a 3" lifted spring in front and a 2" spacer as well cause I atleast wanted to level out the truck but with just the 3" spring it brought it back to stock height and when I put the spacer back in it leveled it out so I'm confused as to what's going on....
Old Nov 17, 2016 | 09:34 AM
Verify that your spring is actually a 3" lift..... any numbers/tags on it?
Old Nov 17, 2016 | 10:31 AM
David Clauder
Just the sky jacker logo and the paper work that came with it. I know when I took the spring from a 2500 that I had in there out and set em beside each other the new ones were about a half inch to an inch bigger than the 2500 spring
Old Nov 17, 2016 | 10:41 AM
Is your truck an Off Road Edition?
Old Nov 17, 2016 | 10:46 AM
David Clauder
No. It's not
Old Nov 17, 2016 | 10:59 AM
Good lookin' truck though.... Wish mine were in that good of shape.... Michigan winters play hell on body work.
Wonder if the rear has just settled some over time...... or if a previous owner didn't modify it some....
Old Nov 17, 2016 | 07:50 PM
David Clauder
When I got it the front just had 2" spacer.
Should I put factory springs in with a 3" lift kit?
Old Nov 17, 2016 | 07:52 PM
David Clauder
I've got off road mods I want to do to it . Wished bit were a 24 valve. It has 250k on it. Manual 5.2l and I have gasket work to do to it. I just want the ride to be better.
