1991 Dakota wants to stall coming out of a stop
91 Dakota with 250,340 miles. Runs good but I've been chasing this issue that it want's to stall coming out of a stop. Pushing the gas pedal very little but steady it just starts to miss but wont die, if I give it a bit more gas it goes away and it works fine. When I first start it in the morning it's worst when it warms up it gets better but still there. Already changed spark plugs(old ones looked good) put in Bosch double platinum also new TPS, MAP sensor, Coolant temperature sensor and no leaks in vacuum hoses or codes! I'm lost any suggestions??? The idle speed control motor is working fine although I have move the adjustment bolt in and out and I have no Tachometer in the truck so idle speed is a guess. Previous codes it had were coolant temp sensor (replaced) and idle speed control(fixed).
If you want to keep this rig for a while it would serve you well to read the FAQ page. Some ideas of what I would do in your situation. The dealer told me the Dakotas were designed for Champion plugs. I have the 94. Bosch has a good name because of German built tools but they build a lot of stuff in China and other places now and their auto products are not as good. Does it have a TV cable? Adjusting it would affect idle. You may have an intake plenum issue. I would go through all of the electrical connections to injectors, sensors and the PCM. Clean them with electrical cleaner and then grease them with dielectric grease. Don't over do it use an acid brush. You might use a wire brush to take off the oxidation on the ones you can get to easily. You might pull the injectors and see if the O ring is good. Oh yea throttle position sensor might be going off. That is the first thing I was told to do when I bought mine and had similar issues. I ended up doing a lot of stuff and learning a lot. The other two things could be the switch plate/cam sensor(circular disc like a circuit board under the rotor in the dizzy. It has the wire coming off it.) and the crank sensor.
Minor correction to onemore94dak - he has a Magnum; the 1991 is a LA.
So no crank sensor, and the "cam sensor" is a "distributor pickup" in the 1991 (might even be the same part, but it does a slightly different function.)
Also, the 1991 is throttle body injected; quicker and easier to whack on the connections due to being only two injectors on it.
It won't have the inlet plenum problem; that came with the Magnums for 1992.
RwP
RwP
