O6 dodge cummins
Old 01-20-2017, 12:43 PM
Mreno100's Avatar
Mreno100
Mreno100 is offline
Default O6 dodge cummins
Yes I am working on a 06 dodge cummins and it was having a hard time starting bought new batteries fixed problem. Tell weather hit -24 then fuel gelled up and replaced filter it started fine next day and know even if it's ran for a hour if your turn it off it won't start without ether and I told the guy it's really bad to start with ether
Old 01-20-2017, 01:34 PM
p38251's Avatar
p38251
p38251 is offline
Heater grid working? Fuel heater working?
Old 01-20-2017, 09:41 PM
Mreno100's Avatar
Mreno100
Mreno100 is offline
Not sure best way to test them out the coil light is on but isn't popping any codes
Old 01-21-2017, 12:51 AM
Chet Ubetcha's Avatar
Chet Ubetcha
Chet Ubetcha is offline
3rd Gen Ram Moderator
Moved over to the smelly forum. Hopefully these guys can help give you a better answer.
Old 01-21-2017, 07:55 AM
nibroc's Avatar
nibroc
nibroc is offline
Smelley forum?????????????????
Old 01-21-2017, 02:38 PM
p38251's Avatar
p38251
p38251 is offline
Does the heater grid light go out? Should be able to hear the relays cycling.
Old 01-21-2017, 05:35 PM
Mreno100's Avatar
Mreno100
Mreno100 is offline
No just stays on constantly
Old 01-21-2017, 07:09 PM
p38251's Avatar
p38251
p38251 is offline
Sounds like either the grid or relay is bad. May need to check for power in and out of the relay. Check fuses first
