fuel pump
Old 02-15-2017, 11:42 AM
demonkota's Avatar
demonkota
demonkota is offline
Default fuel pump
ok i replaced my fuel pump and its still not pumping i swapped out the relay and still nothing.... could the new pump be bad or is there something im not doing.......
Old 02-15-2017, 12:28 PM
jkeaton is offline
Is it getting power?
Old 02-15-2017, 12:54 PM
robertmee's Avatar
robertmee
robertmee is offline
What he said....is the ASD relay turning on? Pull the connector at the top of the tank...using your FSM and a meter check that you're getting 12vdc when you turn on the ignition.
Old 02-16-2017, 05:50 PM
demonkota's Avatar
demonkota
i dont have anything to check it but swapping the relays but still want. the part store told me to bring it back and they will give me another one.
Old 02-16-2017, 06:54 PM
volaredon's Avatar
volaredon
volaredon is offline
but if you do not have electrical power and ground getting to it, the next new pump won't work either.
Old 02-17-2017, 02:01 PM
demonkota's Avatar
demonkota
true is there a fuel cut off switch on these models?
Old 02-17-2017, 03:02 PM
RalphP's Avatar
RalphP
RalphP is offline
Yes, there is! It's called the ASD relay ...
There's no inertia switch per se, though. Not like the one in the trunk of my Cougar, that can be tripped by thwacking the driver's fender as you walk by ...
RwP
Old 02-17-2017, 03:04 PM
RalphP's Avatar
RalphP
RalphP is offline
I'll add to Robertmee - pick up a copy of the Factory Service Manual (FSM), pick up a cheap multi meter (heck, they come up for free at Harbor Freight if you keep an eye on the coupons!), and check the voltage at the pump connector for the 2 seconds or so after the ignition switch is turned on. You can also jump the ASD and make sure it keeps power on.
RwP
Old 02-17-2017, 05:41 PM
TurboRev's Avatar
TurboRev
TurboRev is offline
Is it an aftermarket or OEM pump? I ask this because some get confused as to which wire is which with aftermarket pumps and are connected incorrectly drastically affecting the voltage.
Old 02-17-2017, 06:47 PM
volaredon's Avatar
volaredon
that should not matter, wiring plug positions should be the same
