Clunk and jerk when giving gas and letting off
Old 03-28-2017, 11:48 AM
tomgreene's Avatar
tomgreene
tomgreene is offline
Default Clunk and jerk when giving gas and letting off
96 5.2 4x4 manual. Since I got the truck a year ago it has jerked every time I quickly let off the gas or step on it when in gear. It makes a pretty loud clunk too. For the past couple months it has also made an awful clunk/grinding noise that seems to be coming from the front end when I take off from a stand still. You can feel it through your feet and passengers have noticed it too. I haven't read anything that's specific to these trucks, only general forums that say it's motor mounts. How should I check these? I've tried to push the engine and it does not move even slightly. It just feels like my entire front end is loose. What checklist should I go through? This is driving me crazy. Thank you
Old 03-28-2017, 01:02 PM
volaredon's Avatar
volaredon
volaredon is offline
One thing that has gone out on every Dakota I have had (I am on Dakota#6) is the motor mounts. That would definitely cause what you are describing.
Old 03-28-2017, 08:08 PM
RalphP's Avatar
RalphP
RalphP is offline
Motor mounts; transmission mount (I'd do both motor mounts and the transmission mount at one time; I did the motor mounts, then later discovered the transmission mount bad on my Cougar (pic attached of the old and new transmission mounts)
Also, don't ignore your U-joints!
RwP
Old 03-29-2017, 11:17 PM
tomgreene's Avatar
tomgreene
Thanks for the replies. Is this what I'm looking for to do the mounts? https://m.summitracing.com/parts/ani-2652/none/images I have checked the u joints and they don't have any play so it must be the mounts! I've seen many different kinds when looking them up, ranging from $5 to $42. Not exactly sure what part I need. I haven't gotten a chiens to get a good look under my truck yet
Old 03-29-2017, 11:29 PM
RalphP's Avatar
RalphP
RalphP is offline
That looks right; but it's twice what RockAuto gets for it.
http://www.rockauto.com/en/catalog/d...tor+mount,5552
Also, do the transmission mount; http://www.rockauto.com/en/catalog/d...ion+mount,8756
You may need to tear into the U-joints. At that age, I'd suspect them even if you can't get any slack into it.
RwP
Old 03-30-2017, 06:57 AM
volaredon's Avatar
volaredon
ujoints can freeze/bind up too which you may not catch until you pull the shaft, getting loose and sloppy aint the only way they go bad. They are cheap, your truck ain't new no more go ahead and replace them. Get some reputable branded ones... not some parts store "house brand" crap.
Old 04-02-2017, 02:22 AM
tomgreene's Avatar
tomgreene
looks like i'll be ordering some new mounts very soon! thanks for the website, turns out the 4x4 has different mounts than the 2wd. a bit more $$ too. oh well. I'll look into the u joints too. 21 year old truck i'm not surprised everything needs to be replaced!
Old 05-10-2017, 10:26 PM
WiLiV's Avatar
WiLiV
WiLiV is offline
Did you put them in yet? I know the tranny mounts on these things shred like tissues.
I also have a manual, and I have to let off the clutch like a granny when upshifting so the transmission doesn't thump on the floor.
Old 05-11-2017, 12:20 AM
shadowthedakota's Avatar
shadowthedakota
shadowthedakota is offline
There's tsbs out on alldata for the clunking noise in all dakota manual trucks. It's nothing to worry about. It's very common as all my manual trans vehicles including my civic do that.
Old 05-17-2017, 12:55 AM
tomgreene's Avatar
tomgreene
I've actually only replaced the passenger motor mount so far. I haven't had the time to do the others. No difference whatsoever from replacing the one mount, the old one actually looked just fine. Hopefully the tranny mount will do the trick. I'll have some time to do it in a couple weeks and I'll post an update then
