1500 Towing w/factory bumper hitch?
Bought my 98 Ram 1500 SLT used. It has a 2"ball on the bumper. The bumper looks sturdier than the conventional car bumpers,appears to be a steel tubebolted to the frame just like the aftermarket people do,so I'm thinking this thing might be capable of actually towing something (like a car) without adding an aftermarket gizmo. How do I find out what the capacity if and is this truck is equipped with a towing package other than a pretty ball (do Rams even come with a decorative hitch rather than a working one?)
RE: 1500 Towing w/factory bumper hitch?
I most definatly would not trust a ball mounted in the bumper, Id even be worried with that set up pulling a jet ski. If your towing a car on a dolly you would be smart to get a factory or aftermarket hitch, (with a reciever). I am sure you could rob one off an wrecked dodge at the junkyard, Dont forget the wirering harness. GL
The bumper looks sturdier than the conventional car bumpers,appears to be a steel tubebolted to the frame just like the aftermarket people do, -------- if the 'steel tube' is attached to the bumber.. wouldnt that be the hitch? UNDER the bumper? has the removable sleep where the ball attaches too? mine has it and i have the 99 ram 1500 .. and i tow all day long with it.. have a tow dolly and tow lots of cars.. even trucks..
I believe that you are talking about this:
If so, I've pulled my buddies Expedition out of mud before using it, but I didn't actually tow anything with it.
I think I'd get a proper hitch to do real towing.
[IMG]local://upfiles/54080/AB39796E0ABE48A18BAE56FDFF99098E.jpg[/IMG]
ORIGINAL: ExiledTiger
ORIGINAL: ShakyJay
If the truck had a factory tow package you would have a receiver hitch under the bumper.
Yeah I towed using my 1&3/4" and 2" *****.
For light trailers they work fine, jetski's work trailer.
But I did overload it and bent my bumper, so there is a limit..... and it is stamped on the bumper.
If you gonna really pull weight, get a hitch put on.
Well all I can say is that if you are talking about the factory bumper, with my first dodge I towed my brothers car (a small suv) on a double axle trailer from texas to oklahoma with it. Had no problems. It probably was not the smartest thing but hey i was 18 and didnt know any better. A guy I know uses it to tow his boat all the time with no problems. If it was me I would put a hitch on just to be safe. In fact my new dodge came with one so no more bumper tows.
ORIGINAL: Silver_Dodge
Which tells you that if they thought it was strong enough to tow from, the factory tow package would not come with a receiver hitch mounted to the frame. I wouldn't to anything from the bumper myself.
ORIGINAL: ShakyJay
Bottom line is that yes you can tow using the bumper however you will need to make sure your wiring is correct and your weights are within the limits. I would not recommend heavy duty towing but small boats and trailers are not out of the question.
