1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
engine codes
Old Apr 17, 2007 | 11:18 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: engine codes
TPS code could be high low or out of range ... Did you CHECK it ???
Old Apr 18, 2007 | 01:49 AM
blackvenge34's Avatar
blackvenge34
honestly im not quite sure how to check it and not i didnt i cant untill i go home on friday
Old Apr 21, 2007 | 03:24 AM
blackvenge34
ok i got a voltimeter from my bro but i dont know what settings to put it on n all im trying to find the booklet to c what setting and can i have a little info on exactly what to do to check the voltage and if its to high or to low what do i do thanx
Old Apr 21, 2007 | 04:26 PM
blackvenge34
ok i checked the voltage its a five and it still bounces and goes to 1500 rmp what else does that mean i need a new one? thanx
Old Apr 21, 2007 | 04:49 PM
blackvenge34
ok my cel when on again and its reading 24 code again but i checked the voltage again and its still 5 volts im not really sure what else thanx sorry for the multiple posts in a row
Old Apr 21, 2007 | 06:42 PM
rthegremlin2's Avatar
rthegremlin2
TESTING
See Figures 1, 2 and 3
In order to perform a complete test of the TPS and related circuits, you must use a DRBĀ® or equivalent scan tool, and follow the manufacturer's directions. To check the Throttle Position Sensor (TPS) only, proceed with the following tests.
Visually check the connector, making sure it is attached properly and that all of the terminals are straight, tight and free of corrosion.
The TPS can be tested using a digital ohmmeter. The center terminal of the sensor supplies the output voltage. [*]
Connect the DVOM between the center terminal and sensor ground. [/ol]
Fig. 1: Throttle position sensor connector terminal identification
With the ignition key to the ON position and the engine OFF check the output voltage at the center terminal wire of the connector. [*]
Check the output voltage at idle and at Wide Open Throttle (WOT):
For 1995 vehicles at idle, the TPS output voltage should be about 0.5 volts. At WOT, the output voltage should be about 3.7 volts. The output voltage should gradually increase as the throttle plate moves slowly from idle to WOT. [*]
For 1996-98 vehicles at idle, the TPS output voltage should be about 0.38-1.20 volts. At WOT, the output voltage should be greater than 0.6 volts. At WOT, the output voltage should be less than 4.5 volts. The output voltage should gradually increase as the throttle plate moves slowly from idle to WOT. [/ul][/ol]
Fig. 2: Checking resistance of the TPS, which reads 4.51K ohms with the throttle lever closed
Fig. 3: While checking resistance of the TPS, readings should change smoothly in proportion to the opening angle of the throttle lever
Check the resistance of the TPS as follows:
Unplug the TPS connector. [*]
Using an ohmmeter, or a DVOM set to the ohms scale, measure the resistance between terminals 1 and 3 of the connector on the TPS side. [*]
Resistance should measure 3.5-6.5K ohms. [*]
Measure the resistance between terminals 2 and 3 of the connector on the TPS side. [*]
Measure the resistance with the throttle closed, with the throttle about halfway open and at wide open throttle. [*]
The resistance should increase smoothly as the throttle plate is opened. [*]
If resistance measures outside these values, replace the TPS. [/ol][*]
Before replacing the TPS, check for spread terminals and also inspect the PCM connections. [/ol]
