1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
95 dodge avenger won't start
Old Apr 17, 2007 | 10:37 PM
venice73's Avatar
venice73
Default 95 dodge avenger won't start
I just purchased a 95 dodge avenger with 169000 miles on it. It has a valve leak and I took it to the car wash to clean the engine to be sure. It started when I left the carwash but would not start the next morning. The fuel pump comes on and the starter turns over but will not run.Have I shorted something out or should I let it dry out first? It as been drying for about one day now.
Old Apr 17, 2007 | 11:16 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: 95 dodge avenger won't start
I'd guess you wetted something you should not have ... Either the Computer or distributor ... I'd check and see if you have spark then work from there
Old Apr 18, 2007 | 05:28 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Welcome to DF Venice73.
Did you, or the car wash worker, cover the distributor cap, computers, relays, battery, and other things that aren't supposed to get wet in the engine bay? My guess, something shorted out or is shorting out. A day in 75+ degree summer can help, but not a day below 75.
Follow BV's advice and let us know where you stand after that.
