1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
break lights and ABS
Old Apr 27, 2007 | 01:27 AM
cjc12's Avatar
cjc12
Default break lights and ABS
ok a 95 avenger's break lights wont turn off and i know that there is a lever or switch under the pedal and a little black piece is supposed to trigger the lights to go off ...... but while driving home the ABS light came on and i dont think there is supposed to be a connection in that situation.
am i wrong? is there something im missing ?
please help.
Old Apr 27, 2007 | 05:07 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: break lights and ABS
Yoiur brake LIGHT switch is triggered by the pedals ... It's likely bad if the brake lights are on constantly ...
The ABS light is showing troubles in the ABS , both are unrelated ...
Old Apr 29, 2007 | 02:15 AM
blackvenge34's Avatar
blackvenge34
ok my abs light went on a while ago and i changed the pads im guessing a sensor but not sure and not sure where the sensors are to be checked any one know where or what to do
Old Apr 29, 2007 | 08:32 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
The ABS sensors are on the backside of the hubs and they are on all four corners. Hopefully, you didn't accidentally damage one of them by pulling on the signal wire bro.
Old Apr 29, 2007 | 08:39 PM
blackvenge34
i dont think so the light when on before i changed the pads and never went off so im guessing bad sensor but not sure and if there are four how do i know which one and r they hard to replace and are they cheap
Old Apr 29, 2007 | 09:57 PM
bad venge's Avatar
bad venge
Section Moderator
It's easiest to get it scanned for codes on the brake system ... It's normally either the sensor or the ABS ECU unit ... Sensor look at the wires one of mine got hit by something off the road I guess and cut them I spliced it and it was OK ... MY ABS unit went out onse and it was a $40 part at the junkyard
