1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Grinding noise from rims.
Old May 3, 2007 | 01:45 PM
Avenger901's Avatar
Avenger901
Default Grinding noise from rims.
I bought me some new rims the other day (18's). They had my car jacked up and they back rims where fine. When they put the front one's on they wouldnt spin. It was pushed up against the caliper keepin it from moving. So I went to get some spacers. I got them put on. Now the rims can spin but they are grindin a little.What can i do to get this noise to stop?
THANKS, RON
These are the rims i got http://www.fortewheel.com/pdut_detail.asp?ID=101
Old May 3, 2007 | 03:22 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Grinding noise from rims.
It's pretty obvious that there is STILL a clearance problem you'll have to find out what's hitting the rim and see what can be done ...
Check the Calipers , Inner A arm top inside ... and outside fender well lip ...
Old May 3, 2007 | 04:31 PM
Schrum's Avatar
Schrum
If it still barely rubs and you need just a little wider spacers, you might be able to put some washers over the studs.
Old May 3, 2007 | 05:07 PM
Avenger901's Avatar
Avenger901
I kno its the caliper. But imma try adding some washers
Old May 3, 2007 | 07:47 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
What are the rim offsets Ron, curious. Stock rim offsets are 46mm. Did you get rims with a higher offset number?
Old May 4, 2007 | 01:11 AM
bad venge's Avatar
bad venge
Section Moderator
I WOULD NOT add washers ... the wheels need a FLAT seat to properly seat ... Adding the washers will push the wheels out but will not support the wheels properly AND can damage the lugs if you MUST try it put them BEHIND the spacers
Old Jul 2, 2007 | 03:03 PM
Avenger901's Avatar
Avenger901
the rims are 40mm. i talked to a guy and he said he can put adapters on all for tires for $200. should i get them?
Old Jul 2, 2007 | 06:50 PM
bad venge's Avatar
bad venge
Section Moderator
$200 is pretty expensive for four 6mm spacers ....
Old Jul 3, 2007 | 06:38 AM
silvercoupe97
Uber Moderator
I have 40mm offsets and I don't rub anything behind the rims? Do you have big brakes? What size tires do you have? Are they wider than 215? It shouldn't be since you have 18s. Is your car slammed to the ground? Do you have wide rims?
I don't think your rims are grinding anything. Unless you mean when you turn...
Old Jul 3, 2007 | 09:43 AM
Avenger901's Avatar
Avenger901
the size tires i got is 215/40/18. and its not the tire that is grindin its the rims its self. its hittin the caliper. just a little. i will post a pic of where it grinds at.
