1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
studder problem
Old May 4, 2007 | 09:27 PM
blackvenge34's Avatar
blackvenge34
Default studder problem
ok sometimes it does it while im driving but mostly crusing on the highway my car will pause once in a while then it started to get worse and it does it multiple times i had a 3 hr drive and it did it constantly throughout the trip and when i had cruise control on it kept shutting off
Old May 5, 2007 | 03:50 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: studder problem
The torque converter maybe causing your shudding. ck the trans for codes,you may have stored code for the torque converter control.
Old May 5, 2007 | 10:52 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Explain this "pause".
Old May 6, 2007 | 12:12 AM
blackvenge34
its like a misfire kinda i guess it ill studder once then twice the a couple more times in a row then one every so often on the on the highway but sometimes regular driving almost litke i lose power for a sec or sumthin its hard to explain
Old May 7, 2007 | 10:04 AM
silvercoupe97
Uber Moderator
A stutter in motor or a stutter in power transfer to the wheels (follow up with Tech's post about the TQ).
When was the last time you changed your plugs and wires?
Old May 7, 2007 | 03:05 PM
blackvenge34
i'd say studder in the motor i changed the coil pack plugs and wires probably round feb.
