1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
STILL DYING
Old May 10, 2007 | 06:01 PM
25Avenger's Avatar
25Avenger
Default STILL DYING
Okay I am about to give up and burn the car. As stated before my car is just dying for no apparent reason. We have changed the ASD relay and it is still dying.
I will be driving down the road everything is fine and then it just stops running, no warning no nothing. You wait any where from 20 to 30 minutes and it will start back up. It will usually die again withing a few miles. Any ideas before she becomes dust?
I am not sure where else to turn but the dealer and that is going to be big $$$
Old May 10, 2007 | 07:31 PM
josef15111's Avatar
josef15111
Default RE: STILL DYING
Hey man just a thought have you checked out the PCM like had it test for codes or anything. i know mine was dying too until i got a newer PCM it hasnt done it since.... I have even heard that the ground wires can be all gunked up with grime and dirt try cleaning them up and making sure they are all in good shape.. what about the crank postion sensor i am hearing that they are like a number one cause of your car acting stupid.. these are just thoughts but you never know one may fix it..
Joe
95 2.5 ES
Old May 11, 2007 | 04:53 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
That issue sounds like the CPS, that Joe stated, creating your issue. I'm guessing from your s/n that you have a 2.5L. If so, your crank position sensor is located just below the distributor. It's not a difficult job, but if you don't have a Haynes/Chiltons manual already, get one.
Joe is right, the CPS is like any other electrical sensor that is subjected to the environment, it will break or give errors.
Old May 11, 2007 | 05:29 PM
25Avenger's Avatar
25Avenger
Thanks guys! We will check the CPS this weekend and try and replace that.
Old May 15, 2007 | 05:44 PM
25Avenger's Avatar
25Avenger
It turned out to be the CPS - now it runs like a dream!
Thanks guys!
Old May 15, 2007 | 06:20 PM
JokerzVeng's Avatar
JokerzVeng
Grtaz bro...
Old May 20, 2007 | 02:41 AM
73dart's Avatar
73dart
Can you check the crank pos sensor and the cam pos sensor with an Ohm meter and what should you be seeing. Mine is doing the same thing.
Old May 20, 2007 | 03:04 AM
shooter5045's Avatar
shooter5045
mine too but now mine wont start. i switched the cps but i do not know if i wired it right. could that have ruend the new cps?
Old May 20, 2007 | 12:18 PM
rthegremlin2's Avatar
rthegremlin2
I believe both of the sensors need to be checked with an oscilliscope.
