Driver Handle Won't Open Door
Recently I have been having some problems opening up my door from the drivers side. I know the handle isn't broken because i doesn't flop around or anything. I can still open the door from the inside no problem.
I removed the door panel; the arm that conects the door handle to the actual mechanism that opens the door still operates, the rod does its job, but as I pull the handle as much as I can, the rod stops short of opening the door. It just needs just a bit more pressure and leverage (by pushing down on the rod) to finally pop open the door.
The rod is bent, but it looks like it is supposed to; I tried bending the rod inward to make the distance the rod travels less but to no avail. Any suggestions?
