1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
WONT START
Old May 20, 2007 | 04:34 AM
element000101's Avatar
element000101
Default WONT START
ok I would try to start the car, and it wouldn't start, it would crank but not Start, so i waited a while and then it started, but then i tried to start it today and got nothing out of it, im seriously had enough with this car, can anybody help me...plz
Old May 20, 2007 | 12:19 PM
rthegremlin2's Avatar
rthegremlin2
Default RE: WONT START
Crank position sensor most likely.
Old May 20, 2007 | 06:43 PM
element000101
i dont got spark though
Old May 20, 2007 | 08:25 PM
rthegremlin2
exactly.
Old May 20, 2007 | 10:24 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
List what you've done to resolve this so that we aren't suggesting what you've already done.
Check to make sure you get fuel by listening for the fuel pump prime when you first turn the ignition to the on position and before you crank the car over. If you get that, I would then start with the ASD relay, crank or cam sensor (crank being the most common to go since it's exposed), then the final thing is either the ECU. The ECU is the less common over the rest btw.
Old May 21, 2007 | 11:29 AM
element000101
im just hoping its not the ECU...its going in the shop today
Old May 22, 2007 | 01:24 AM
silvercoupe97
Uber Moderator
What's the scoop, Element?
Old May 22, 2007 | 11:52 AM
element000101
i dont know the guy hasnt called me back, so im getting worried...but once i geta call ill let you know, if it is the sensor how much are the anyways...what about the EIS my step dad said...electronic ignition system...lol i dont know haha
Old May 25, 2007 | 08:20 PM
tvfoxdude's Avatar
tvfoxdude
Mine did the exact same thing, and it was the cam sensor that is inside the distributor, I thinkthe new distrib.I got at Advance Auto was right around $200. Have'nt had a problem since.
Old May 26, 2007 | 09:59 PM
silvercoupe97
Uber Moderator
ORIGINAL: element000101
The ignition timing is all done with the crank, cam sensors, and ECU, not to mention the many sensors inbetween all of that. So if your ignition timing (includes fuel injector timing) is off, your source signals can be mixed up or even the relay that give them the ok to be powered up.
