1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
turbo prep
Old May 24, 2007 | 07:56 PM
sprman9's Avatar
sprman9
Default RE: turbo prep
Ive heard that the 2.5 is better for turboing due to the thicker walls? But I understand having a bigger engine to get more power. Still need to research for myself, but I have seen that posted somewhere on the forum I believe.
Old May 25, 2007 | 12:05 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
I think I may have posted that or quoted that from Steve Martinez (Exile Racing).
Old May 25, 2007 | 12:19 AM
bad venge's Avatar
bad venge
Section Moderator
I'm not sure how much thicker the walls are as some one is running the 2.5 heads on the 3.0 block ... if there was a difference I'd doubt that would work
sprman9's Avatar
sprman9
I believe that is correct silver. wasnt intending to steal thunder anywhere...
Old May 25, 2007 | 12:53 AM
silvercoupe97
Uber Moderator
No thunder stolen Sprman9
I'll have to look for it and quote it, but I think Steve said the difference wasn't huge, but thicker is thicker. If you think about it, the 6g73 is basically a bored out 6g72. It made sense to me when Steve brought it to light and it stuck.
Old May 25, 2007 | 01:28 AM
sprman9's Avatar
sprman9
https://dodgeforum.com/m_631357/tm.htm
That would be where you said the 2.5 walls are thicker.
Old May 25, 2007 | 01:35 AM
silvercoupe97
Uber Moderator
Good find bud. I wish I had quoted Steve on that one. As you can see that was in 2006 and Steve had been saying that for some time before then.
