1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
turbo prep
Old May 23, 2007 | 03:27 AM
sprman9's Avatar
sprman9
Default turbo prep
What would be recommended to turbo a car. A 96 ES would have tobe rebuilt, andI would like to know what to rebuild to handle a little more power.Also, an intercooler would be beneficial asI understand. If anyone has any specific brand they really like... no clue on this. Dont have much money, but I'm either gonna get a new exhaust, or wait untilI get everything for a turbo.
Old May 23, 2007 | 03:32 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: turbo prep
You should wait to get your exhaust done because you will need to redo the exhaust and have it come off the turbo instead of off the exhaust manifold. If you want to rebuild your motor, you will spend a pretty penny doing it. Roughly about $3k for the turbo kit and another ~$2k-4k forthe rebuild. The build would consist of rods, pistons, 4 layer head gasket, stronger head bolts, not to forget the tranny build consisting of an LSD (wheel hop is going to be bad without it), high stall torque converter (I'd recommend Exile's rebuilt A604 that is made to put up with a boosted motor. There's more, but you get the gist of it.
Old May 23, 2007 | 03:07 PM
josef15111's Avatar
josef15111
Hey silver do you have a site or something with all the products i would need to rebuild my motor for a nice turbo setup? Iv looked a lil bit but havent found what i need can you help out..
Old May 23, 2007 | 03:26 PM
bad venge's Avatar
bad venge
Section Moderator
Howell sells a nice rebuild kit , or even a shortblock already done ...
Hahn makes a nice turbo kit ...
Old May 24, 2007 | 07:49 AM
silvercoupe97
Uber Moderator
I agree with BV, the sites are also listed in the resource list located in the FAQ section.
Old May 24, 2007 | 12:02 PM
josef15111's Avatar
josef15111
Hey guys i got to looking in the stickys and i havent found anything on a rebuild kit for the 2.5 can some one point me in the right direction please... thanks
Joe
Old May 24, 2007 | 12:47 PM
silvercoupe97
Uber Moderator
Well, Joe, you have a 2.5L. You'll have to go with Exile Racing...if you can get a hold of them.
http://store.exileracing.com/index.p...6f3dcab98483da
This was in the resource list FAQ also.. Avenger resource list
Old May 24, 2007 | 01:45 PM
bad venge's Avatar
bad venge
Section Moderator
Truthfully I'd NOT waste the money ... A 3.0 swap is CHEAPER and more power ... A 3.0 motor wqith 6K miles cost me $600 shipped to the door .... You'lll triple that amount in PARTS only for the rebuild + labor and machining will runn around $3k
Old May 24, 2007 | 04:15 PM
josef15111's Avatar
josef15111
ok so your saying i would pretty much be happier with the 3.0 swap both performance and price wise. well i like the sound of a 3.0 being in there i want some where around 300hp can i achieve this outta that motor with doing minimal things to it? 2k sounds way better than 8k to build up what i was wanting too. i will be doing this in the beging of next year around the spring time. Bad if you have any info laying around on this swap hook me up i know about the stikys and must have read them a million times but you never know some one out there just might know more. thanx for the time guys
my email is josef15111@sbcglobal.net
joe
Old May 24, 2007 | 05:09 PM
bad venge's Avatar
bad venge
Section Moderator
300 HP is VERY optimistic unless you boost or juice ... 300 is pretty tough on the tranny too ... I blew three before my Level ten one ... It's held up over the years so far (like 50K)... I'll see what I can throw together for the 3.0 swap
