1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
anther wont start story
Old May 24, 2007 | 03:12 PM
mudd's Avatar
mudd
Default anther wont start story
like u said my car wont start.it is a 95 2.0 i have relpaced the pcm the plugs and wires the fuel pump the crank shaft censer. umm batt and alternater. i get spark and it cranks but it wonr turn over. my asd relay does turn off and on though what shoud i do???
Old May 24, 2007 | 03:25 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: anther wont start story
next obvious question are you getting gas ???
Old May 24, 2007 | 04:38 PM
mudd's Avatar
mudd
i believe so...when i wave a screw driver in front of the crack shaft cencer i hear the fuel pump turn on.....is there any other ways to check...
Old May 25, 2007 | 12:08 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
When you turn the key to the on position, before you start the car, listen for a whine or humming noise, that's your fuel pump priming. If you don't hear that, you're not getting fuel.
Old May 25, 2007 | 01:22 AM
master tech's Avatar
master tech
Site Moderator & Tech
Will the engine crank over at all ? And do you have compression?
Old May 25, 2007 | 03:31 PM
mudd's Avatar
mudd
i dont hear any whine noise or any noise at all!!!???? and idk if i have any comperssion but it cranks hard like it wonts to start it just wont.
Old May 25, 2007 | 05:44 PM
mudd's Avatar
mudd
the guy i am having work on my car still insits that the pcm we had sent off to be re calibrated in still now good. he has found one off a neon with that he says is the same moter. my question is can i take a pcm off of it or a eclipse or a sebring or a talen or fo they have different settings???
