1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Need Head Gasket Replacement Info!!!!
Old Jul 1, 2007 | 11:12 AM
Crazytrain101's Avatar
Crazytrain101
Default Need Head Gasket Replacement Info!!!!
Does anybody have a printable step by step on tearing down the top half of the 2.5. My Timing belt broke while I was going 60mph, I was told I should take the heads off and visually inspect the tops of my pistons for any damage and also to check all the valves for any damage. I have a manual "Chiltons" but would like to have the advice, and instructions of someone who has been there and done that. Thank You.
Old Jul 1, 2007 | 03:55 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Need Head Gasket Replacement Info!!!!
Likely all/most of your valves are trashed ... also damaging the pistons ... these are zero clearance motors at 60mph you trashed everything ...
Your best thing to do is a 3.0 swap you'll be $$$ ahead with a newer more powerful motor
Old Jul 2, 2007 | 10:00 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Sorry Crazytrain, but BV is right. Even if there was a slim chance that the valves and pistons are fine....you've got the motor opened already and the motor is old, change them out anyway.
There's a parts list in the FAQ section above this forum for the 3.0 swap with the info that you need for the swap if you decide to go that route.
Old Jul 3, 2007 | 09:10 PM
Crazytrain101
Ok I really appreciate the info I will keep you posted on my progress.
