1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
blue smoke
Old Jul 27, 2007 | 07:00 PM
blackvenge34's Avatar
blackvenge34
Default blue smoke
wats it mean when blue smoke comes outa the exhaust my bro said it was smoking a bit and my car was due for an oil change so i did it and after blue smoke came out a bit does that mean i filled it with to much oil i might have half a qt or so
Old Jul 27, 2007 | 09:16 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: blue smoke
Blue smoke is burning oil coming out of the exhaust ...
Old Jul 28, 2007 | 08:56 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
How much smoke is coming out? If it's a lot, you may have a blown head gasket. I would check the oil for coolant and the coolant for oil regardless. I would also check your PCV valve and breather hoses (the two hoses that come from the valve covers and go into the intake tract). I would also pull a plug and check it for oil, on the plug and the in the chamber.
Old Jul 28, 2007 | 10:06 AM
blackvenge34
it wasnt much just a little bit but im gonna see if it does it today but ill check those other things aswell thanx
Old Jul 30, 2007 | 11:58 PM
master tech's Avatar
master tech
Site Moderator & Tech
As a engine gets a lots of mileage, the valve seals starts to leak oil on top of the exhaust valves causing the blue smoke, and if it go away after a few mins its okay, but if have blue smoke after it been warm up. You may have piston ring problem. ( maybe oil ring )
Old Oct 8, 2007 | 02:08 AM
gumpster's Avatar
gumpster
Might want to check the plugs too.
They may be oil fouled.
