1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
brake warning light/e-brake light
Old Aug 16, 2007 | 11:05 PM
JokerzVeng's Avatar
JokerzVeng
Default brake warning light/e-brake light
ok was hoping some of the vets around here may know whats happening here(BV..Silver)
my brake warning light/e-brake light is comong on when i start my veng (still 98 420a MtX) but after i drive bout 15-20? min. its goes off can anyone gimmie a clue what this would mean?...thanks in advance as always..
and no i dont have ABS...
Old Aug 17, 2007 | 10:35 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: brake warning light/e-brake light
check for level of brake fluid ... when it heatrs up it expands light goes out ...
Old Aug 17, 2007 | 10:37 AM
dynamiteplaya3's Avatar
dynamiteplaya3
im also have my anti brake light on and i know for a fact taht my abs isnt working because a dog jumped out infront of me and i locked em up... what can cause the abs to go out and how can i fix it.
Old Aug 17, 2007 | 11:39 AM
sprman9's Avatar
sprman9
ive broken abs sensors before... that atleast causes the light to go on. thay arent hard to brake either
Old Aug 17, 2007 | 12:07 PM
bad venge's Avatar
bad venge
Section Moderator
ABS can be the sensors the computor or the modulator ....
They can run a scan and tell you what it might be ...
Old Aug 17, 2007 | 06:02 PM
JokerzVeng's Avatar
JokerzVeng
ok it was low(down to the bottom of the bracket) was hoping that wasnt it cuz i had to take strut bar off halfway to get my cap off...lol...so im thinking i prolly i have a leaky wheel cylinder(cheapest problem..)
i took it out last night and hammered on the brakes and only fronts locked up so ima go outside and jack up the rear a lil later and find out whats up witht he rear brakes i thought the braking was a lil subpar anywayz. ill let you guyz know whats going on..thnx again guyz..
Old Aug 17, 2007 | 09:25 PM
bad venge's Avatar
bad venge
Section Moderator
brake fluid can and does boil off ... It might not be a leak .... just not checked in awhile ... it's normal for the fronts to lock up first ... since 75% of the braking is done there ...
Old Aug 18, 2007 | 12:12 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
...to add to that...as the pads wear down, the fluid follows. A set of low pads = a lower fluid level. It's a good idea to check the pads all the way around too.
