1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Being Cheap
Old 09-27-2007, 07:50 AM
PappiDread6's Avatar
PappiDread6
PappiDread6 is offline
Default Being Cheap
Ima do the AWD eclispe swap, I wanted to know what performance parts I could buy for my current 420A manual Vengethat I can also use on the Mitsubishi 420A. Only thing I could think of is MSDS Coil pack, spark plugs and wires, Piggy back system, underdrive pulley, and prolly sum head work.
And No BV im not doin the 3.0L swap. lol!
Old 09-27-2007, 10:38 AM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Dodge Forum Moderator
Default RE: Being Cheap
cat back exhaust , fuel management, injectors, gauges are all good investments that will work
Old 09-27-2007, 11:39 AM
PappiDread6
Naw ima turbo it so the catback will be a waiste right now. as well as an intake. Gauges I can do with out because I get no HP from them. Would abot injectors, and cams?
Old 09-27-2007, 12:20 PM
bad venge's Avatar
bad venge
Section Moderator
If you are going high performance gauges are a MUST to monitor the motor ... I've seen far too many peeps spendf $3/$5k on a motor then blow it because something went wrong , that proper gauges would have prevented ..
Larger injectors and fuel management can be used on both situations ...
Old 10-01-2007, 08:37 AM
PappiDread6
Damn dog its looks like im gonna have to get it after all my car is too damn slow! I had a 4 ppl in my wip the other day and man! I need new shocks first of all it look like I dropped the suspension. Prolly about 500lbs in total weight. So CAI, 2 1/2 CBE, Underive pulley seems to expensive 4 one part so Ill get the cams, umm and fuel injectors, oh and a stage 1 clutch.
I need a transmission mount and I was gonna replace the one in the rear as well since I already close by. I was wondering should I polyurethane the new mounts or the old ones. I can only keep my car off the road for one day because of work.
Old 10-01-2007, 10:33 AM
bad venge's Avatar
bad venge
Section Moderator
It's easier to poly NEW ones ... since they are already centered and not egged out
Old 10-02-2007, 11:48 AM
PappiDread6
What is that stuff tho? it looks like bondo or but the color and hardening like JB weld.
Old 10-02-2007, 12:28 PM
bad venge's Avatar
bad venge
Section Moderator
It's a polyurathane (similar to rubber) but it's stiffer you mix it and pour it in and let it harden up ...
Old 10-03-2007, 10:28 AM
PappiDread6
aight. off the top of your head do you know the prcie for a motor mount? Ima hit up the dealership and see wut they say. Maybe I can get all 4 for and arm and keep the leg
Old 10-03-2007, 12:26 PM
bad venge's Avatar
bad venge
Section Moderator
I thought I got the motor and tranny mounts for under $100
Quick Reply: Being Cheap
