1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Speaker
Old Oct 13, 2007 | 02:26 PM
sliveravenger97's Avatar
sliveravenger97
Default Speaker
i just bought a 1997 dodge avenger and i have a problem with the speakers. the radio works but i just cant hear anything it has the infinity mr158403 amp in the trunk would there be something wrong my speakers or the amp. can anyone give me a good answer
Old Oct 14, 2007 | 11:13 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Speaker
You need to check voltage on the amp and the remote wire to the amp Larger gauge red wire and white wire with black/silver dots... since you just got it the former owner might have had an aftermarket stereo , or disabled it ....
Old Oct 15, 2007 | 01:12 AM
sliveravenger97
Default RE: Speaker
i bought it from a used dealership. but it still have the same radio and it doesnt look like the head unit was removed. how do u take the amp out because its mounted in the trunk so would i have to go behind the back seat where the speakers are and take off the cover if so how do i get all that stuff off. also could i bypass the amp if i put in an aftermarket head unit
Old Oct 15, 2007 | 10:41 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Speaker
you can check the voltage without removing the amp panel...just check wiring in the plugs....
Disabling the amp canbe done BUT there are 6 channels...aftermarket decks have 4 channels
