1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Alarm?
Old Oct 16, 2007 | 08:37 PM
Haze99avenger's Avatar
Haze99avenger
Default RE: Alarm?
also if i just take out the relay and alarm horn will it cause in any way the car not to start because of incomplete circuits or not?
Old Oct 16, 2007 | 08:45 PM
Haze99avenger
Default RE: Alarm?
are you saying the relay is most likely under the dash
hey badvenge do you have AIM because i noticed were goin back and forth between two topics.... lol may make things easier
Old Oct 16, 2007 | 08:53 PM
Haze99avenger
Default RE: Alarm?
didnt think about that... so what i want to do check volts if there is 12 then the horn is bad if not then it could be the relay or a short right
Old Oct 16, 2007 | 09:15 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Alarm?
Correct ... no aim allowed on work computers ...
Old Oct 16, 2007 | 09:19 PM
Haze99avenger
Default RE: Alarm?
oh i didnt know you did this at work, ummm.... i should be able to handle that then... im probably eventually gonna get an aftermarket, but till then it would be nice to have an alarm, i would probably be able to get a new horn from the dealer im guessing....
Old Oct 16, 2007 | 09:21 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Alarm?
junkyard or even airhorns ect from the parts store ...
Old Oct 16, 2007 | 09:37 PM
Haze99avenger
Default RE: Alarm?
yeah and an air horn is probably more likely to grab attention than a regular horn right
