1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
neon install help
Old Oct 16, 2007 | 08:09 AM
95_dodge_avenger's Avatar
95_dodge_avenger
Default neon install help
i just got a under body light kit, it has 2 36 inch and 2 48 inch tubes, i was wonderin the best loaction for the lights on a 95 avenger with a 2.0 5 speed standard trans?
Old Oct 16, 2007 | 10:42 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: neon install help
48's down the sides... 36's front rear ...
Old Oct 16, 2007 | 12:03 PM
95_dodge_avenger
well, yea, but where can i mount them on the front and back?
Old Oct 16, 2007 | 12:23 PM
bad venge's Avatar
bad venge
Section Moderator
front fits fine under the nose ... I have two sets under there
for the rear you can either mount it to the rear axle or put it across under the rear bumper and use black tape to mask it so it's not as visible ...
Old Oct 16, 2007 | 12:27 PM
95_dodge_avenger
kool
Old Oct 16, 2007 | 02:15 PM
bad venge's Avatar
bad venge
Section Moderator
Old Oct 16, 2007 | 03:29 PM
dynamiteplaya3's Avatar
dynamiteplaya3
orrrrr. in the back u can mount it to the gas tank. thats what i didmight not be the best place but it works. and really if u live in ohio my uncle is a state hoopie and he said there really isnt a law agenst STEADY neons.as long as they do not strobe, but he said they will try 2 pull u over for them since it they make u think that they are illegal but if they do pull u over and issue u a citation all u have to do is take it to court and the court will over turn the ticket because there is no law agenst it. and my rear neon is showing and ive never had a prob with the popo.
Old Oct 16, 2007 | 03:41 PM
dynamiteplaya3
kind of a ****ty pic... taken during the day and they kinda look orange but they really are red
Old Oct 18, 2007 | 12:28 PM
95_dodge_avenger
my next question is how do u get the mounting screws in to the car, iv dried drill, screwdriver, im gettin to a point to where im bout to break the bulbs, i would like to speek to someone in person bout this, my number is 832-790-6325
Old Oct 18, 2007 | 03:55 PM
95avenger's Avatar
95avenger
front and back i used zip ties and tied it to wherever i could get them to hold. my rear tube is ziptied to the rear axel (and i turned the led's to shine out behind the car to light the back of it). front is ziptied to the black like rock chip things on the left ans right of engine compartment. for the sides the kit came with self drilling screws and i drilled strait into the "floorboard" from underneath the car; but the edge that hangs down creates a shadow line where the glow ends
