1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Fuse?
Old Oct 20, 2007 | 11:02 PM
stewdog9's Avatar
stewdog9
Default Fuse?
What would cause my running lights not to work and my car not to start when i turn the key, only some things work, like headlights, relays all click when i turn the key and fog lights etc. All the fuses under the hood and dash are fine. help please
Old Oct 20, 2007 | 11:07 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Fuse?
fusible links off the battery terminal (two whiteish wires)??? running lights could have burnt out the dimer switch ...
You say don't start , need more info ... does it turn over ??? no spark ??? what ???
Old Oct 20, 2007 | 11:32 PM
stewdog9's Avatar
stewdog9
Default RE: Fuse?
my bad, when i turn the key the last click to turn the car over, thestarter does not do anything at all, only noise or movementin the whole caris the relays clicking. does not sound or smell like anything is jammed or anything.
Old Oct 21, 2007 | 12:11 AM
95_dodge_avenger's Avatar
95_dodge_avenger
Default RE: Fuse?
what all still works?
Old Oct 21, 2007 | 12:51 AM
stewdog9's Avatar
stewdog9
Default RE: Fuse?
just thedash lights, like the check engine lights and oil lightsbut not the lights that turn on when you turn your running lights on, the radio and room lamp work.
Old Oct 21, 2007 | 01:11 PM
stewdog9's Avatar
stewdog9
Default RE: Fuse?
where is the fusible link? and there was a little black wire that was broken off that bolts on to the block of the engine, it looks like it plugged into a tiny capacitor, behind the exhaust manifold.
Old Oct 21, 2007 | 03:06 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Fuse?
Well if you READ my post there should be two whiteish wires off the battery terminal that run downward... Those are the fusible links ...
Old Oct 21, 2007 | 03:17 PM
stewdog9's Avatar
stewdog9
Default RE: Fuse?
i did READ your post but is there a little fuse block on them because i dont see it, or do the white wires just fry.
Old Oct 21, 2007 | 03:21 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Fuse?
the white wires are the fuse , thats why they are called fusible links ... they open up ... you'll need a voltmeter or an ohmmeter to test them ... check for voltage at the opposite ends of them Or remove the battery terminals and check for continuity ...
Old Oct 21, 2007 | 03:39 PM
stewdog9's Avatar
stewdog9
Default RE: Fuse?
does it show where they open up or does it just happen inside the wire, because i pulled the wire wrap all off and i didnt see anything wrong with the wire.
