1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
NOISE
Old Oct 29, 2007 | 08:08 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: NOISE
YES you can ... call dodge customer service ... they will cover it ... you might have to rant and rave but explain that it is a recall and it MUST be done they WILL cover it ...
Old Oct 29, 2007 | 08:20 PM
fallen884's Avatar
fallen884
Default RE: NOISE
i bought it form ray suzuki in for valley. srry if it seems like i am arguing i just want to make sure, so even though it is used i should still call ray suzuki and tell them.
Old Oct 29, 2007 | 08:42 PM
cbccadet2002's Avatar
cbccadet2002
Default RE: NOISE
you can take it to any dodge repair shop. i purchased mine used and they covered it. i didn't even know about the recall before hand. if its a factory recall it will be covered by dodge or chrysler. if they argue then ask for the manager and explain that its a factory covered recall. no questions asked.
Old Oct 29, 2007 | 08:54 PM
johnnybegood_5's Avatar
johnnybegood_5
Default RE: NOISE
Sorry to highjack,but this recall... i just purchase my 95 avenger from a dealership as is. Im also in Canada, Ontario. so if i call a dodge dealer they have to fix the two bad balljoints for me? Is there any proof of this recall? I had to buy the whole control arm with the ball joint so it cost me alot, but i have not put them in yet! So any info asap would be great.
Old Oct 29, 2007 | 09:00 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: NOISE
YES it must be taken to a Dodge dealer the suzuki dealer has nothing to do with this ...
Dodge will even reimburse you if another shop has done the work and you payed for it ...
Chrysler has put out a recall on all 95-00 Sebrings (coupes only) and Avengers for their ball joints and lower control arms.
If you haven't done so, GET THIS CHECKED OUT. In extreme cases, people have lost steering in their car or even lost a wheel while driving.
Facts:
1) The ball joint recall covers ALL YEARS of avengers and sebrings (coupe sebring, not convertible.)
2) The recall covers the ball joints and front lower control arms.
3) The recall covers the parts FOR THE LIFE OF THE CAR. Don't let the dealer pull the whole "the recall was already performed" crap. If the dealer tries this, call the Chrysler recall center (info below).
4) Some dealers will service the recall by 'repacking' the ball joints. Push them to replace the joint, as this 'repacking' WILL eventually fail.
5) If you need to, call the Chysler recall center (like I had to). Have your VIN number ready. They were very helpful & assured me that the recall was for the life of the vehicle (which the dealer told me was BS). They can also get on the dealer's *** if they refuse to do the work (which they did for me).
Here's contact info for the Recall center:
Contact Us by Telephone
1-800-853-1403
M-F 8:00AM - 8:00PM (EST)
Contact Us by Mail:
DaimlerChrysler
P.O. Box 610207
Port Huron, MI 48061-0207
Old Oct 29, 2007 | 11:18 PM
fallen884's Avatar
fallen884
Default RE: NOISE
they refused u, and u pretty much talked them into to it, well think i will be giving the local dodge dealer a call tomorrow.
Old Oct 30, 2007 | 10:36 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: NOISE
They Repacked mine the first time , then said that the recall was performed ... I called the # and ranted about it being repacked instead of replaced ... They replaced it for me no charge ... Others have had three sets installed at dodge expense
Old Oct 30, 2007 | 04:09 PM
fallen884's Avatar
fallen884
Default RE: NOISE
****, i just called them and they were like o no it has alreafy been replaced and they were like the purpose was to get the old style out and the new in and they dont know if they will re doit. is that bsull**** or does it sound right
Old Oct 30, 2007 | 10:58 PM
fallen884's Avatar
fallen884
Default RE: NOISE
nm well i called the recall center and they gave the dodge dealer a call and he said o nm if it is the ball joint they will replace it. aawwsssoommmee
Old Oct 31, 2007 | 10:36 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: NOISE
TOLD you ...
