1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Oil Pressure
Old Oct 27, 2007 | 07:30 PM
Beasty's Avatar
Beasty
Default Oil Pressure
ok i posted before about my 98 dodge venge but theres something im not sure about on the engine like my oil pressure gauge on my dash, once the car is started and running shouldnt that show one constand measurement instead of the needle going up and down with the rpms? i cant figure out if its suppost to go wit the rpms or if its a steady pressure? can anyone help?
Old Oct 27, 2007 | 08:20 PM
95_dodge_avenger's Avatar
95_dodge_avenger
Default RE: Oil Pressure
it should be one measurement, u should check, or even change ur oil, is it a 2.0 or 2.5, the 2.0 takes 4 qurates of oil, the 2.5 takes 5 quarts of oil
Old Oct 27, 2007 | 08:26 PM
bad venge's Avatar
bad venge
Section Moderator
It's normal for slight needle movement with RPM's as the pump is run harder with higher revs ...
Old Oct 27, 2007 | 08:34 PM
95_dodge_avenger
how bad does the needle move?
Old Oct 28, 2007 | 02:37 AM
Beasty's Avatar
Beasty
i have the 2.5 v6 but ok u know how the gauge has 4 sections when im at idle it goes down to one quarter then as im driving the faster i go the higher the needle goes and ive gotten it to about 3 quarter i didnt think that was normal
also would that effect horsepower at all?
Old Oct 28, 2007 | 09:09 AM
95_dodge_avenger
the 3 qurtar is not normal ill look in to that for u
Old Oct 28, 2007 | 10:14 AM
bad venge's Avatar
bad venge
Section Moderator
That could be normal what viscosity oil are you running ???
Old Oct 28, 2007 | 03:00 PM
Beasty's Avatar
Beasty
just regular oil nothing special like synthetic altho i did put a bottle of lucas in my engine but its done that long before
Old Oct 28, 2007 | 08:29 PM
bad venge's Avatar
bad venge
Section Moderator
I'd say it's normal ... mine fluctuates about the same from idle to full throttle ...
Old Oct 28, 2007 | 08:45 PM
Beasty's Avatar
Beasty
well i know on older cars its suppost to stay one steady pressure so i wasnt sure cuz like i said before that i know alot about cars but older cars when it comes to all this computer **** i have to ask to be sure........
