1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
INTAKES
Old Oct 30, 2007 | 11:19 PM
fallen884's Avatar
fallen884
Default INTAKES
what is the difference between a short ram intake and a cold air...
Old Oct 31, 2007 | 10:35 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: INTAKES
short ram is about where the stock intake ends , the cold air drops down into the front near the ground to allow picking up cooler air outside of the engine bay ...
Only drawback is it is dangerously close to the ground and larger puddles/hard rain can suck water into the engine causing major damage (hydrolocking)
