1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
power lock
Old Nov 11, 2007 | 06:38 PM
95_dodge_avenger's Avatar
95_dodge_avenger
Default power lock
im replaceing the factory alarm in my 95, the brain was fried anyway, but does the avenger have power locks? when i got her, it didnt have a clicker thing
Old Nov 11, 2007 | 06:45 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: power lock
You have to tell us if it has power locks... if the drivers door has a lock unlock switch then yes you do ... as for keyless lock/unlock likely if you have power locks yes ... you can get the remote off of ebay
Old Nov 12, 2007 | 02:23 PM
95_dodge_avenger
it dosnt have a switch, but it had a alarm, so would that make it keyless entry also?
Old Nov 12, 2007 | 07:52 PM
bad venge's Avatar
bad venge
Section Moderator
If you have no lock/ unlock on the drivers door panel you don't have power locks .... the only way you'd have keyless is if someone installed actuators in the doors and a remote unit aftermarket ....
Old Nov 13, 2007 | 12:27 PM
95_dodge_avenger
got it installed, i just hooked up the power wires ant the siren and the light wires and starter defeat wires, left all the accessory like power doors, windows and trunk wires unhooked
Old Nov 13, 2007 | 04:01 PM
johnnybegood_5's Avatar
johnnybegood_5
95_dodge_avenger , For the system you put in, could you tell me how u hooked up the starter? I have a Avital Tornado system in my car and i was told it has auto start but a wire or something went bad. Any help would be great.
Old Nov 13, 2007 | 09:11 PM
bad venge's Avatar
bad venge
Section Moderator
Wire - Color - Location
Constant - 12V+ White - Ignition Switch Harness
Starter - Black/Red - Ignition Switch Harness
Ignition - Black/White - Ignition Switch Harness
Ignition 2 - Blue - Ignition Switch Harness
Accessory - Blue/Black - Ignition Switch Harness
Tach - Brown - Coil
Neutral Safety Wire - Black/Yellow (-) - Switch Driver's Side of Transmission
Brake Switch - Green - Brake Switch
Trunk Pin - Red/Green (-) - Trunk Light
Parking Lights - Green/White - Left of Steering Column
Head Lamp - Red (-) - Steering Column Harness
Door Trigger - Red/Black (-) - Driver's Kick Panel
Door Lock - Brown/White (-) - Driver's Kick Panel
Door Unlock - Brown (-)
Horn Wire - Green/Black (-) - Steering Column White 3 Pin Connector
Windows Up - LF=Green/Red, RF=Brown/Yellow MAIN
Windows Down - LF=Green/Black, RF=Green/Yellow
Old Nov 15, 2007 | 04:49 AM
95_dodge_avenger
u need to remove teh panel under the steering wheel, and right under the coloum on the right side, ull see a fat white wire, thats the starter wire, i had to cut that wire and hook it up to the starter defeat wires on my alarm
