1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Dead Avenger
Old Nov 17, 2007 | 06:20 PM
BigBoy121988's Avatar
BigBoy121988
Default Dead Avenger
About a month ago i started up my 96 avenger and everything was fine. As i started to leave the parking lot at school my car shut down and didnt start up. You can here the fuel pump pumping and ive checked the distributor coil, asd realy, cam shaft senor, timing belt,the crank shaft sensor all the spark plugs. The starter is fine but im not getting any spark at all. Any suggestions on wat it could be?Thanxs
Old Nov 17, 2007 | 07:30 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Dead Avenger
Check the relays and the CPS testing above ... how did you check the distributor coil ???
Old Nov 17, 2007 | 07:50 PM
BigBoy121988
i pulled the one out of my buddys avenger
Old Nov 17, 2007 | 11:33 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
How did you "check" the CMP and CKP? Because a physical inspection will only tell you if they're physically damaged.
And start by seeing if the PCM has stored any fault codes.
Old Nov 18, 2007 | 04:27 PM
BigBoy121988
me and my dad tore the whole car apart and swaped out the crankshaft sensor and tested the camshaft sensor. the mechanic across the street said that these cars have problems with the volts acually getting to the sensors and injectors. I ran the codes and it came up 11 and 12.
Old Nov 18, 2007 | 04:37 PM
bad venge's Avatar
bad venge
Section Moderator
Volts getting to the sensor is the relays I reffered to on the first post
CEL codes
11
No crankshaft reference at PCM
Check connector at PCM / Check crankshaft position sensor
11
Timing belt skipped 1 tooth or more
Check timing belt / Check crankshaft sensor and camshaft position sensor / Check PCM connector
11
Intermittent loss of camshaft position or crankshaft position
Crankshaft position sensor and camshaft position sensor connector
12
Direct batter input to PCM was disconnected within the last 50 key-on cycles
Check Battery connections / Informative Code
12 is you disconnected the battery
