1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Keyless Entry??
Old Nov 18, 2007 | 12:35 AM
m_laney06's Avatar
m_laney06
Default Keyless Entry??
Just wondering how i would go about installing keyless entry into my venge. Would it be difficult or easy? Thanks
Old Nov 18, 2007 | 09:34 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Keyless Entry??
Wire - Color - Location
Constant - 12V+ White - Ignition Switch Harness
Starter - Black/Red - Ignition Switch Harness
Ignition - Black/White - Ignition Switch Harness
Ignition 2 - Blue - Ignition Switch Harness
Accessory - Blue/Black - Ignition Switch Harness
Tach - Brown - Coil
Neutral Safety Wire - Black/Yellow (-) - Switch Driver's Side of Transmission
Brake Switch - Green - Brake Switch
Trunk Pin - Red/Green (-) - Trunk Light
Parking Lights - Green/White - Left of Steering Column
Head Lamp - Red (-) - Steering Column Harness
Door Trigger - Red/Black (-) - Driver's Kick Panel
Door Lock - Brown/White (-) - Driver's Kick Panel
Door Unlock - Brown (-)
Horn Wire - Green/Black (-) - Steering Column White 3 Pin Connector
Windows Up - LF=Green/Red, RF=Brown/Yellow MAIN
Windows Down - LF=Green/Black, RF=Green/Yellow
This is the wiring for remote start/keyless/alarm system ... unless you are fairly profescient with electrical work it's probably best to have it professionally installed ... We run a remote start keyless for $99 installed
Old Nov 18, 2007 | 05:01 PM
PappiDread6's Avatar
PappiDread6
OOHH!!! I thought they were $200 I want one. Who u work 4?
Old Nov 18, 2007 | 05:23 PM
bad venge's Avatar
bad venge
Section Moderator
I ran a shop before ... There are several shops here that still run the special
