Sound System
#21
RE: Sound System
Well I had a custom made deck in the back, having a 94 Mustand hatchback.
The deck was put right behind the back seats and cut off the room behind the backseats and the trunk so it was kind of like a trunk normally. Installed the Infiniti Cappas in the deck and it was amazing. I could turn the radio all the way up (the radio pushing 275 watts itself) with the two 6x9s cappas with 750watt amp and it was just epic. No other words can describe it.
If you hvae a hatchback you'll most likely want a professionial to do it for you.. but otherwise you can just replace the original 6x9s and hook them up to an amp and hear the animosity that music has to offer.. even several blocks away.
#22
RE: Sound System
Josh, what brand did you go with? I currently have a Pioneer cassette deck with the cd changer in the trunk. I was there when I bought the car. I purchased a SONY Xplode flip down cd that operates a changer, but dodge factory speakers are crap. Even the ones in my Durango are "busted." I would some SONY xplode 3 way 5 3/4" and the 3 way 6x9s. Should I run with this? I want something my stepson will enjoy when he drives it, but something I will also enjoy when I'm in it. I listen to my music load, but I like clarity.
Ang
Ang
#23
RE: Sound System
I have the stock mirror on the ES. is there Any way possible to tighten the Rear View Mirror is there any nut or screw or anything that tightens it up??? and also i noticed on the inside of my car the roof will vibrate too it feels like there is about an inch of space between the interior roof and the exterior part is there any way to make that not rattle around. no big deal im just OCD and hate problems lol
#25
RE: Sound System
Hah the funny thing is, i do have a sunroof. but i dont have the thing that closes over the sunroof (sunroof cover or w.e its called) so im thinkin i might b able to shove sumthin back there like a small folded up blanket or sumthing so when it rattles its hittin the blanket and cuttin down on the rattling.. Think it'll work?
#26
#28
#29
RE: Sound System
ok this has to do with the sunroof deal. When i bought the car off of the previous owner, the sunroof was broken.. some part on one side of the sunroof broke off and was causing it from sealing correctly. so he took it to a mechanic and the mechanic just temporarily fixed it by sealing it back up. But he could not use the sunroof or it wouldnt seal right again. so me and my dad were messing around with it one day and we got it to open and close fine but the back right side of the sunroof will literally with little finger strength pop out... should this be possible or not. and i notice if i shut my passenger door hard the sunroof will rattle and sometimes the back end will pop out as well.
