1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
96' Avenger Multiple Misfires
Old Nov 18, 2007 | 08:38 PM
sparkie791's Avatar
sparkie791
Default 96' Avenger Multiple Misfires
Hi Everyone!
I'm a newbie. I'm getting a code #43 multiple mis-fires. This is a 4cyl DOHC Coupe. I've changed plugs, wires, coil pack, pvc valve. Camshaft sensor and Crank Sensor were also changed about 15K ago for intermittent shutoffs. Can't get this engine light off. Whenengine lightflashes, I can feel the car jerk. Also jerks really bad if I turn off the OD by mistake. Someone suggested I may have a leak in the manifold gasket. Any other less labor intensive ideas that I can try first? I have one month to get this to pass emmisions.
Sparkie
Old Nov 18, 2007 | 08:57 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: 96' Avenger Multiple Misfires
I'd recheck work done ... Did the plugs look dry ??? No oil ???
Other possibles are :
Ignition coil / Spark plugs / Ignition circuit / Injector / Upstream HO2S / Compression pressure / Timing belt / Crankshaft position sensor / Air intake / Fuel pressure / Crankshaft position sensor circuit and connector
