1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Dash speakers
Old Nov 23, 2007 | 10:14 AM
offduty97's Avatar
offduty97
Default Dash speakers
I have a question about the dash speakers on my 1996 Avenger. I already bought the replacement Bose 301 tweeters as recommended on this forum, my question is do the covers on the dash speakers just pop off or do I have to take the whole dash off to get to them?
Next question is I am going to replace my door and rear speakers as well. I have the infinity amp with the factory stereo (which I would just assume keep). I have read that the amp has a built in crossover for the door and dash speakers, so does that mean that I shouldn't look for a strong tweeter set up in the door speaker and just look for good, solid woofers since the tweeters are routed tothe front. I don't want to disable the amp and bypass it, just keep it the way it is with new speakers.
Thought I would ask before I tear up my dash by digging around. Thanks in advance.
Old Nov 23, 2007 | 11:34 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Dash speakers
dash tweets just pop out get a screwdriver in and pry up they are held in with butyl rubber
if you were replacing the door speakers I would have recomended getting a component set thus using the tweets for the dash and the midrange for the door no tweeter really needed
Old Nov 23, 2007 | 03:19 PM
offduty97's Avatar
offduty97
ok, thanks. I may look at some components for the replacements in the door anyhow, luckily I didn't spend a lot on the bose tweeters. thanks again!
Old Nov 23, 2007 | 08:08 PM
bad venge's Avatar
bad venge
Section Moderator
No Problem ...
