1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Water Damage
Old Jan 3, 2008 | 03:21 PM
99avenger913's Avatar
99avenger913
Default Water Damage
I have a 99 avenger 2.5l v6 I was in an accident and my car went into a pond got it towed home all the electrical works. When I try to start my car the engine doesn't crank. It just makes a loud ticking noise. I want to know what could be wrong so i can fix it.
Old Jan 3, 2008 | 08:39 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Water Damage
Did you charge/replace the battery ???
Try to give it a jump???
Did the car go in the water running???
Old Jan 4, 2008 | 10:31 PM
PappiDread6's Avatar
PappiDread6
If it went in the water while running it might be hydrolocked. Im really hopin you battery or starter is fried or something. If its not just pull the spark plugs , get some of the stuff you put into your gas tank to get rid of water and pour a lil into the piston chambers (I heard rubbing alcohol works as well) spin the crank a lil and burn the tips of your spark plugs with a lighter to get rid of sum of that water on them re install and try it again.
Old Jan 5, 2008 | 06:41 PM
99avenger913
As soon as I went into the water I turned the car off. I tried to jumped it and when I tried to start it up it was a loud ticking noise. It wouldn't crank at all.
Old Jan 5, 2008 | 07:55 PM
bad venge's Avatar
bad venge
Section Moderator
If it truly hydrolocked the motor is likely toast .... I've seen severe piston/rod damage due to hydrolocking ...
Old Jan 5, 2008 | 08:26 PM
99avenger913
I'm going to try to check the spark plugs and and the starter I hope it's not hydrolocked, if it is then I have to get a new engine[:@]
Old Jan 5, 2008 | 08:41 PM
bad venge's Avatar
bad venge
Section Moderator
since it happened in the accident it should be insurance replacing it ...
