1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
avenger alternator removal 2.5
Old Jan 25, 2008 | 02:28 PM
mike98avgenger's Avatar
mike98avgenger
Default avenger alternator removal 2.5
Old Jan 25, 2008 | 07:32 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: avenger alternator removal 2.5
There are two ways ...one out the bottom very hard unless you have a lift/or pit ....
Other way is to remove the intake plenum and pull it out the top ...
Old Jan 26, 2008 | 01:02 PM
Sroufe7's Avatar
Sroufe7
Take off the plenum and pull it out the top.
It really isn't that hard, but every one makes it seem like it is.
Just make sure and tape off the lower manifold so you don't drop anything down it. [:-]
Old Jan 26, 2008 | 01:37 PM
bad venge's Avatar
bad venge
Section Moderator
Yes I pull it out the top takes about an hour
Old Jun 26, 2011 | 06:34 PM
tjsounds2010's Avatar
tjsounds2010
now does anything else have to be removed to get the alternator out? i am having the same problem with my 98 2.5 motor
Old Jun 26, 2011 | 07:03 PM
bad venge's Avatar
bad venge
Section Moderator
not really it's a rita to get loose without a kift but can be done on jackstands ect
Old Jun 29, 2011 | 03:29 PM
tjsounds2010
thanks so much for your info guys. got the aternator out and put the new one in..works awesome. thanks again guys
Old Jun 29, 2011 | 05:23 PM
bad venge's Avatar
bad venge
Section Moderator
Awesome ...
Old Oct 11, 2012 | 02:42 PM
ADIVA2NV1's Avatar
ADIVA2NV1
remove a alternator 2008 dodge avenger
Old Oct 12, 2012 | 05:59 AM
bad venge's Avatar
bad venge
Section Moderator
The first gen 95/2000 is TOTALLY different then the 08 , I'd post that question in the proper section
