1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Still Dying At Idle
Old Feb 23, 2008 | 09:20 AM
Goose's Avatar
Goose
Default Still Dying At Idle
I’m having the same old problem with dying at idle. I really want to fix it myself before I end up taking it into the shop, but its been like this for nearly a year, and I’m getting frustrated. Basically, when I’m going, its fine, but as soon as I put on the breaks or slow down, it dies out. Starts up fine, and idles fine as long as I don’t start to drive it. Once I drive and stop it dies. What in the world is the problem here? I did the whole plugs, wires, distributor cap and rotor business, and that didn’t solve the problem. My other car is getting repoed this next week, so I need to get my Avenger running again.
Old Feb 23, 2008 | 07:57 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Still Dying At Idle
First off go and get some seafoam and run it thru the intake per instructions ... I'm guessing the IAC Idle air control is dirty ...
Old Mar 2, 2008 | 06:36 PM
RockJay81's Avatar
RockJay81
could be the distributor i had the same problem they changed it out and never died on me like that again.
Old Mar 2, 2008 | 06:53 PM
bad venge's Avatar
bad venge
Section Moderator
Seafoam=$6
Distributor=$200+
I'd try the cheaper thing FIRST
Also if its a distributor trouble there should be a CEL for multiple misfires
Old Mar 3, 2008 | 10:56 AM
yanickee's Avatar
yanickee
I'd say check your EGR valve! Had the same problem couple years ago, had to replace EGR valve. CEL was random multiple misfire
Old Mar 4, 2008 | 07:39 PM
TheZephire's Avatar
TheZephire
mine did that, it was the fuel pump firewall relay...
Old Mar 4, 2008 | 11:19 PM
scatpackmopar's Avatar
scatpackmopar
I want to know how you changed the distributor since Avengers don't have one [they have a coil pack]. Go to the junkyard, find a good looking throttle body with all the sensors intact. Swap the entire throttle body over. If the problem goes way it was one of those sensors. Most likely the TPS [throttle position sensor] You might have other problems buta good mechanic should be able to find this problem out for you.
Old Mar 5, 2008 | 11:41 AM
bad venge's Avatar
bad venge
Section Moderator
V6=DISTRIBUTOR
Old Mar 5, 2008 | 10:35 PM
scatpackmopar
He didn't say which engine he has. I guess I assumed he had the 420A like I do.
Old Mar 6, 2008 | 06:21 AM
Goose's Avatar
Goose
FINALLY! After a year of sitting dead in the garage, I got the problem fixed. It was the EGR valve and a lower intake leak that was causing the problem. Thanks for all your help, I sure hope I dont have to post another help topic anytime soon. Thanks again.
